Results 1 to 11 of 11
Thread: PLease Help
    Steph my1stss's Avatar
    May 2010
    NJ
    2001 camaro ss #4168
    PLease Help
    I have an 01 ss and the check engine light came on 2 days after i purchased it, the cats were clogged so we gutted them and changed all the o2 sensors. Codes P0420 & p0430 came up and I need to go through inspection so I just put Magnaflow converters on it all 4 the o2 sensors are new. Cleared all the codes was good over the weekend and them POW! P1416 code comes up, now what do I do Please help!
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    DTC P1416 Secondary Air Injection (AIR) System Bank 2
    Check the passenger side check valve.
    Detailed instructions on how to diagnose the secondary air system, with pics: http://www.ls1.com/forums/showthread.php?t=130641
    May 2010
    NJ
    Awesome great diagrams thank you! We will try that tonight.
    May 2010
    NJ
    Will I pass inspection with this code?
    SES codes are emission codes. if your SES light is on, most likely they will not even test your car with the OBDII plug in.
    May 2010
    NJ
    i have no lights on at this time?
    Go and try to pass then?
    May 2010
    NJ
    I dont know what to do
    Quote Originally Posted by my1stss View Post
    If you go to your emissions site and get tested and you fail, they will tell you why you failed. Than you can correct the problem and go back again.
    May 2010
    NJ
    I passed!
