Results 1 to 2 of 2
Thread: 58x or 24x reluctor wheel
05-28-2010, 05:28 PM #1
which motor would be better for my 95 camaro? an ls2 with a 58x or 24x reluctor wheel? or does it even matter?
05-30-2010, 06:11 AM #2
it really doesnt matter, if your getting the whole setup, try and get a 2000-2004 computer (reads the 24x reluctor wheel). then if you get a newer motor with the 58 tooth reluctor you can get a converter box for the older computer to read.
the main reason to do it this way is the 2000-2004 computers are more tuneable than the newer computers (you have to trick a few things in the newer computers for fueling when you go alot bigger by using adders) and there are some other small differences
Question: Need answer ASAP!!!!! Verify the Reluctor Wheel on a 04LQ4
By SMWS6TA in forum General HelpReplies: 21Last Post: 05-16-2012, 01:11 PM -
Reluctor wheel/Ecu
By HRT383 in forum Computer & TuningReplies: 2Last Post: 10-08-2007, 12:15 AM -
2007 Reluctor wheel
By ojoojo in forum General HelpReplies: 3Last Post: 03-05-2007, 04:43 PM -
Looking for reluctor rings
By trainingdragon in forum Parts Wanted / TradeReplies: 0Last Post: 07-23-2006, 12:46 PM -
By trainingdragon in forum DrivetrainReplies: 0Last Post: 07-16-2006, 11:38 AM
