Results 1 to 3 of 3
    May 2010
    nh
    2001 formula
    tuning problem??
    i have an 01 formula with cai, lts, catless y, and since i got a mail order tune it has been running inconsistant. sometimes it pulls hard and then other times not near as hard. and lately when i push the gas it is just like i hit the rev limiter at 2000 rpm and will not rev any higher. it revs in nuetral no problem. the plugs are whitish grey which makes me think its lean. fuel pressure is fine, but i have ruined 4 02 sensors in about 3000 miles. they are the corvette sensors. any help would be greatly appreciated. i have really hit a wall here.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Quote Originally Posted by robs01formula88 View Post
    Unfortunately you can't really read plugs (by color) if they have been through normal closed loop operation of the engine.
    It sounds like you have positive fuel trimming making WOT inconsistent. This can happen when a MAF reports low (on it's way out but won't code) for example.
    How do you know the sensors are bad; have you WATCHED them switching and see that they always report low voltage or are you going by codes (which don't necessarily mean that they are bad, depending on the codes)?
    Do you have a scan tool that will let you see real-time engine data?
    Wisconsin
    2001 Camaro SS M6
    Is there anything you don't know about tuning
    But to OP, my car acted the same way with no codes but O2's going out and Frost was right, it was my MAF! Switched it and Bingo, money in the bank!
    ┌∩┐(◕_◕)┌∩┐
    wouldn't want to fight them!
  1. Car backfires after header install, tuning problem?
    By BLCKBRD2000 in forum General Help
    Last Post: 10-09-2011, 05:01 PM
  2. Tuning problem
    By badboy10 in forum Computer & Tuning
    Last Post: 02-09-2010, 06:20 PM
  3. does this sound like a tuning problem....
    By jmatt07 in forum Computer & Tuning
    Last Post: 08-16-2009, 11:47 AM
  4. Tuning problem or more?
    By InsaneWs6TA in forum Computer & Tuning
    Last Post: 04-25-2007, 05:05 PM
  5. Is this a tuning problem???
    By GotN2O in forum Computer & Tuning
    Last Post: 03-15-2006, 06:23 PM
