Results 1 to 11 of 11
05-25-2010, 05:49 AM #1
rear suspension rattle..is this normal?
hey all, ive got an adj phb, relocation brackets, adj lca's, edlbrock trq arm, stock shocks and springs. I noticed that when i go over rough pavement like cobblestones, or the like, eventhough they'll have a smooth surface, the rear suspension will rattle as if there's something loose, and i had it all installed a few weeks ago. What could be rattling?
05-25-2010, 05:51 AM #2
Have you physically inspected under there to see if you can find anything that is loose? Could be that maybe something wasn't torqued down properly.
On the adjustable PHB and LCA's, did you get bushed ends?
Could maybe even be your TA hitting in the tunnel. Clearance on tunnel mount torque arms are nil in our cars.
05-25-2010, 06:06 AM #3
on the lca's i got polys, and on the phb i have the roto joint. the torqe arm is from edlebrock, but i remember it happening before then. i havent been able to inspect it. i had a shop put it all on since they were doing other work for me
05-25-2010, 06:09 AM #4
Could even be the exhaust if they had to loosen it to install some of your components. They might have relocated it a little. Check to see if you have clearance where your exhaust goes over the axle. Aftermarket exhausts can come really close to hitting the top pan hard stabilizer bar where is goes over the axle.
05-25-2010, 06:32 AM #5
ok ill check that tonight. i mean it just sounds like its all over, and rattles on these cars are a pain to pinpoint
05-25-2010, 08:42 AM #6Member
- Jan 2009
- Pa
Hello
Another suggestion for you is to go back through what it was you had the shop due and make sure that all of the hardware is tightened. If you have any other questions feel free to ask.
Thanks
Brad
05-25-2010, 01:57 PM #7Senior Member
- Jan 2010
- texas
silver- 2000 formula
with my spohn LCAs there is some noise.............comes with the territory
05-26-2010, 12:55 PM #8Chief of his tribe!
- Mar 2008
- NYC
Navy Blue Metallic- 2000 T/A Firehawk M6
with my new LCA's there is a little noise as well. Unless it sounds nearly catastrophic there is probably not much to worry about. Get under there and torque everything down nice and tight and get back on the road. See if it improves.
As for mine? Installed, drove, retorqued and even now if I have the windows open i can hear a little noise. A slight squeak here or rattle there. Car actually has a smoother ride and much better handling so no complaints from me over a little noise lol
05-26-2010, 01:12 PM #9
Check for broken sway bar linkages..
05-26-2010, 06:10 PM #10
ok. lscyal8tr, my lca's are new and are the single adjustable. it makes sense now about a little rattle. when i take the car back next week to get the shocks/sways/springs put on ill have them retorque everything down
05-31-2010, 02:15 PM #11Senior Member
- Jan 2010
- texas
Rattle in the middle or rear
By Guerrillakilla13 in forum General HelpReplies: 48Last Post: 02-05-2014, 11:48 AM -
Front Suspension Work / Completed Rear Suspension
By bhunter0830 in forum Suspension and HandlingReplies: 32Last Post: 07-02-2013, 01:23 PM -
By bhunter0830 in forum Suspension and HandlingReplies: 0Last Post: 04-13-2013, 05:44 AM -
Suspension Rattle At Slow Speed
By knappbunch in forum Camaro / SSReplies: 1Last Post: 08-14-2008, 02:36 PM -
How much rear axle play is normal????
By LowSS in forum DrivetrainReplies: 0Last Post: 07-16-2007, 08:20 PM
