Results 1 to 20 of 21
Thread: Annoying rattle!
05-24-2010, 07:59 PM #1
Annoying rattle!
Ever since i had my heads and cam installed, there is this annoying almost unbearable rattle coming from under the car...i just removed the heat shields from the passenger side, and ITS STILL THERE!
When i put the car on a lift you cant hear the rattle, its just when its resonating off the ground.
My next step is just to heat-wrap the entire Y-pipe and see it that does anything.
Any advice would be greatly appreciated!
05-24-2010, 10:03 PM #2
when the cars on the lift you cant locate the rattle? when you did the headers did you do MM as well? What type of headers/y-pipe?
05-25-2010, 04:02 AM #3Senior Member
- Apr 2008
- Madison, WI
How do you make the noise happen? Hard accelleration? what rpm range does it rattle?
05-25-2010, 04:41 AM #4Senior Member
- Nov 2006
- Indianapolis
Sometimes the underbody crossmember will rattle on the exhaust.
05-25-2010, 04:47 AM #5None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
What kind of torque arm do you have?
05-25-2010, 07:05 AM #6
lets see....i have mac mid-length headers and a mac off road y pipe( garbage i know)
didnt do the motor mounts.
it happens at lower rpms when sitting at a stop light or just cruisng slowly.
the problem started after i had a "reputable shop" in the area install new heads and cam. i think they pulled the motor to do the install.
and as far a torque arm, its all stock.
thanks for all the interest! i hope we can get this shit figured out!
05-25-2010, 07:21 AM #7
well....the motor mounts might be one problem, look into the mufflex bump-stop hanger aswell
05-25-2010, 07:57 AM #82002 Arctic White T/A
- Sep 2009
- Houston , Texas
Metallic Pewter- 2002 SLP Firehawk
I also had a rattle after headers,y pipe, and exhaust install. Mine was located right under the drivers side. I have read that this is the spot where most y pipes hit
05-25-2010, 09:41 AM #9
Have you tried taking it back to the shop and bitching? I'm also voting it's exhaust related.
05-25-2010, 11:20 AM #10middle aged teenager
- Nov 2009
- lawrenceville georgia
sunset orange/ black- two 2001 ws6 m6
2 things to check ,first make sure a socket isnt sitting in the collectors if you have headers,2nd check the cats to see if the baffles are loose inside.,.
05-25-2010, 11:25 AM #11middle aged teenager
- Nov 2009
you guys may laugh but ive seen it a few times where the socket falls from the top and lodges itself where the 4 tubes come together.
tap the cats with something and if its that you will hear the baffles rattle a little
05-25-2010, 11:48 AM #12
no socket, and i have no cats...
i took it back 2 or 3 times and the prick just says they dont hear it and they checked it out. as soon as i get the car back it rattles again.
the guys at that shop are a joke. they really f'd up my car. it now also leaks some red fluid (tranny i image), rattles, and has just become a pain in my ass and embarassing.
i got the heads and cam done over 2 years ago and have been dealing with this crap ever since!
05-25-2010, 12:37 PM #13
05-25-2010, 12:53 PM #14
Two years ago.......dammit I was going to suggest making the shop guys ride with you so they hear it, but I guess after 2 years that opportunity is gone.
05-25-2010, 01:16 PM #15
05-25-2010, 02:13 PM #16Senior Member
- Mar 2010
- St Pete, FL
Bat mobile black- 2000 Trans am WS6 M6
where does it sound like the rattling is coming from? y pipe, inside the motor, header area, under the car, inside the engine bay? specify
05-25-2010, 09:00 PM #17
sounds like its coming from behind the engine area to me...but some of my friends say it sounds like its in the back...its a mystery!
from inside the car it sounds like up front passenger side.
05-26-2010, 07:57 AM #18Senior Member
- Mar 2010
- St Pete, FL
has to be the headers. try putting a video up
05-26-2010, 08:51 AM #19
Driver side could be coming into contact with the steering linkage. On some header brands it gets real close.
05-26-2010, 05:52 PM #20Senior Member
- Apr 2008
- Madison, WI
get some friends to crawl under and around the car while the noise is happening to help pinpoint an area where the rattle is
Help: That annoying clunk/rattle from the front end
By Black WS-6 in forum Firebird / WS6Replies: 1Last Post: 07-25-2010, 04:08 AM -
annoying
By 99ss in forum Camaro / SSReplies: 28Last Post: 02-18-2010, 02:14 PM -
Annoying rattle
By Eric1987 in forum ConvertibleReplies: 6Last Post: 02-19-2009, 04:14 AM -
Help: very annoying
By wanna_lS1 in forum Firebird / WS6Replies: 2Last Post: 11-19-2008, 10:50 AM -
So annoying!!!!
By TempleU_WS6 in forum Almost Anything GoesReplies: 46Last Post: 02-15-2008, 06:34 PM
