Thread: colder plugs
    Member 02fbody35th's Avatar
    Feb 2008
    scranton,pa
    2002 camaro 35th anv.
    colder plugs
    just wondering if any one is running a colder plug on a stock ls1 and if it would be ok to do so. I have been having a detonation problem at high rpms on hot days and was considering a cooler plug to get temps down. do you think this will help. i know i risk fouling the pluggs but it might be worth a shot if it will get rid of the horrible ping.
    Member JRENIGAR's Avatar
    Oct 2009
    arkansas
    99 camaro
    shorten the gap some ( 2-5 thousandths ). Maybe richen it up a lil, pull some timing, or get a colder t-stat.
    Arizona
    Quote Originally Posted by JRENIGAR View Post
    I do all of the above along with colder plugs.
    Just be aware that ACdelco changed their part numbers around as well as deleting some. They no longer carry a part numbered plug for LS motors that signify a heat range. More of a one plug fits all crap so I avoid AC plugs anymore.
    The NGK's never showed any significant heat range changes with EGT's on a dyno last time we played with those so I avoid those as well.
    About the only plugs on the market that I care for and that actually offer various heat ranges that work (aka: showed consistent EGT changes) are Autolites. For a stock heat range on LS1's they call for APP104's which is a double platinum stock heat range.
    Going one step colder would be APP103's. If you don't want the platinum plug and would rather have a copper core, then look at AR103's.
    mercersburg pa
    hugger orange
    2004
    I'm running the autolite AR103's gapped at .040"
  1. Think How Much Colder it Would be if not for Global Warming
    Last Post: 01-12-2015, 06:24 PM
  2. Question: AC delete in colder months?
    By JoshieDoom in forum Firebird / WS6
    Last Post: 09-01-2009, 05:43 AM
  3. Question: Colder plugs and more timing with MSD coils?
    By Chemist in forum GTO
    Last Post: 03-31-2008, 05:25 AM
  4. colder spark plugs
    By Z ROADSTER in forum General Help
    Last Post: 11-08-2007, 08:56 PM
  5. Got Colder...Need a Retune??
    By Wesman in forum Computer & Tuning
    Last Post: 10-31-2007, 08:00 PM
