Thread: Whisper Lid foam gasket
03-01-2006, 06:35 AM #1
- Jan 2006
- Michigan
Red- 02' Z28 M6
Has anyone replaced the black foam gasket that is adhesive that you install on the top of the lid for the seal? I took my lid off while I was pulling my MAf and the gasket has gotten dry and has come off in places. Should I try to make my own? change material? any help would be appreciated.
03-01-2006, 06:44 AM #2
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
Never even noticed on mine.
03-01-2006, 07:16 AM #3
Yea, when I had my Whisper lid mine never had a gasket.?
98 T/A: HPE 5.3 Heads, 238/242 113 cam, Kooks 1 7/8 stepped LT headers, Custom Y pipe, Cut out, Borla, NW 90MM TB, FAST 90MM Intake, TB Bypass, Under Drive Power steering and Crank, 150 Dry NOS, Yella Terra rockers, 3400 TC, HPE tuning,
03-01-2006, 07:36 AM #4
- Jul 2005
- Jacksonville, FL
Mine has one, think it came with the K&N filter/Whisper combo years ago. If you want to replace it just bring a small piece with you to HD or hardware store and get some foam window insulation that's sticky on one side.
03-01-2006, 08:05 AM #5
Yea it comes with the K&N filter, not needed if you use a paper filter, but mine dried and cracked just the same and now I dont have one on there, I think it makes up for poorly fitted lids, which my SLP one is.
03-01-2006, 09:58 AM #6
- Jan 2006
- Michigan
Red- 02' Z28 M6
your right, I did get it with the K&N, not the lid. Sorry, installed it 4 years ago, I will remake one. My lid has always been tough getting to close with a K&N or paper filter. I am going to tear it off and see if there is too much play with the lid and both filters, I would rather not have it coming apart into my intake. Plus, it was a pain in the A$$ to get that damn gasket on the lid in the first place. Thanks for the replies.
03-05-2006, 03:35 PM #7philsls1Guest
i got one also with the k@n filter. not only was it a pain in the a$$ to put on lid but now my slp lid doesn't buckle down on left side. wonder if i remove gasket if lid will snap down the right way
Sea Foam
By badboy10 in forum General HelpReplies: 12Last Post: 02-27-2014, 07:42 PM -
Question: Anyone know what this foam is?
By 02z28ttop in forum Camaro / SSReplies: 2Last Post: 09-02-2012, 01:41 PM -
The FOAM.......
By SuperSSguy in forum Almost Anything GoesReplies: 28Last Post: 07-23-2012, 05:05 AM -
Question: sea foam
By johnny 5 in forum General HelpReplies: 8Last Post: 02-06-2011, 12:48 PM -
Sea Foam
By 99M6Z28 in forum Internal EngineReplies: 5Last Post: 12-18-2005, 09:23 AM
