    Mar 2010
    K S A
    Camaro Z28 LS1 2000
    Unhappy Camaro 2000 Differential NOISE SOUND !!
    Hi All
    I have a trouble with my differential , there are sound like (wooooooooo)
    When i drive the car
    so i already change the ring&pinon and all the bearings form front to rear and from left to right
    But the sound still coming
    some body say to me thats problem coming from gear kit in the rear of differential and some others say that is no solution for that
    SO
    Please Any one can help me with information about this case how i can to solve it and kill the sound totaly
    Iam Waiting You All
    My camaro
    2000 v8 5.7 L AutoTransmission with Traction Control
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    If the rear gears are setup up properly, they shouldn't make very little to no noise. Is it possible that your tires are noisey? If you still think its the rear differential, then maybe you can buy a used replacement or have a more experienced shop rebuild yours
    Pittsburgh
    2008 Hummer H3
    Gm makes an additive to help with the noise. Mine whined @ 26-28k. Had the dealer service it under warranty. They added it to the rear along with the new gear oil. I can't remember what it's called. But an auto parts will carry it, or they can get it for you too..
    East of Cleveland, Ohio
    99 WS.6 - Modified
    What brand of gears did you install?
    Mar 2010
    K S A
    Camaro Z28 LS1 2000
    Thanks all
    I Belive the sound coming from there but i dont know
    my parts from Rechomnd and my oil Is GM with lubracting slip can
    Any way i will replace the gear kit carrer and i will see what will happen
    thanks again
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    Did you adjust the amount of shims from the last set? Replacing bearings won't fix anything if preolad and backlash aren't properly adjusted.
    Mar 2010
    K S A
    Camaro Z28 LS1 2000
    do you mean this part?
    Bay Area
    my highbeams
    The part you circled is the carrier, there are shims on either side that go inbetween the servce spacers that are just below the bearing caps you took off. Did you use a dial indicator then? There is also a shim needed in the pinion that you would use an arbor gauge to determine the size you would need.
    Apr 2009
    Oak lawn, il
    02 T/A WS6
    Richmond gears are loud, thats how they are, but you should make sure that backlash/and all the other adjustments are spot on specially for a factory 10 bolt.
  1. Noise when I step on the brakes making a humming sound.
    By Street Fighter in forum General Help
    Last Post: 12-06-2016, 12:46 PM
  2. Cadillac CTS 4 Rear Differential Noise
    By pajeff02 in forum Cadillac CTS-V
    Last Post: 01-06-2016, 04:34 PM
  3. 1998 Camaro differential swap
    By Dbor1531 in forum Drivetrain
    Last Post: 06-02-2011, 02:58 AM
  4. 1999 camaro ss differential on a yuko??
    By blky2kd in forum Almost Anything Goes
    Last Post: 08-07-2006, 10:36 AM
