Results 1 to 16 of 16
    middle aged teenager WS6S's Avatar
    Nov 2009
    lawrenceville georgia
    sunset orange/ black
    two 2001 ws6 m6
    Question knock sensor code ?
    my 2001 ws6 is throwing a knock sensor code,i reset it but it came back again,should i just replace the sensor ?
    What is the exact code it is throwing?
    I wouldn't fool around too much with the knock sensor, if it is bad, replace it ASAP.
    Pittsburgh
    2008 Hummer H3
    This ..
    Nov 2009
    two 2001 ws6 m6
    ya the car isnt gonna move till i do this,i guess i will change both of them ? advance wants around $ 40 ea tomorrow i will see what gm wants.
    Nov 2009
    two 2001 ws6 m6
    bank 2 code
    phoenix
    04 2500 4x4 crew cab
    Do yourself a favor while you are in there, and replace the wiring harness too. I had to open my intake three times the first time I replaced them.
    Nov 2009
    two 2001 ws6 m6
    Quote Originally Posted by az gt eater View Post
    why did you have to replace the harness :?
    phoenix
    because it still threw a code.
    Nov 2009
    two 2001 ws6 m6
    now im thinkin while i got the intake off i might as well pull the heads and do a full cam swap in her ?
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    Quote Originally Posted by WS6S View Post
    Go for it!
    Member Baluchitherium's Avatar
    It has a big wing!
    Oh of course! Wouldn't want to waste an oppurtunity right?
    1999 Firehawk Trans Am #530
    Nov 2009
    two 2001 ws6 m6
    got the harness and 2 sensors from my local chevy dealer $ 151.00 delivered to me.i keep flip floppin on the cam issue.to do it the way i want im lookin at around $1500.00.i just dont really have the cash to play with right now.guess im gonna wait a little while.
    phoenix
    im glad you got both sensors and the harness. I had the car throw the knock sensor code just recently when i tried for emissions this year, and i just went ahead and ordered it all. I got everything off ebay new for just a little less than you got your stuff. I changed it all the first time, and no problems. And fyi, i sealed the new ones in last time with rtv, and it didn't do any good. I'm sure it is because water gets under there. Between the intake and block.
    Nov 2009
    two 2001 ws6 m6
    my issue is to just fix it and be done or keep rippin it down and cam it.
    phoenix
    Sounds like you need to have that convo with your banker. Can I suggest you rub her back and cook her a meal first?
    Nov 2009
    two 2001 ws6 m6
    im gonna pass on the sit down with my banker ( she has a fat back and will eat way to much ) and just continue ripping my motor apart.monday i will call around and see about the vengance racing vrx5 cam or something else.i figured it at around $ 1500.00 for the cam,springs,pushrods,lifters,oil pump,timing chain,gaskets,studs and trunnions for the rocker shafts.oh and the tune.its just amazing how all i was doing was replacing a friggin knock sensor !
  1. Knock sensor code and spark plugs....
    By Spikito in forum External Engine
    Last Post: 03-30-2013, 03:09 PM
  2. knock sensor code with new knock sensors?
    By zaaronz in forum General Help
    Last Post: 02-27-2011, 07:26 AM
  3. Knock Sensor Code...
    By Spikito in forum General Help
    Last Post: 09-20-2010, 11:27 PM
  4. Question: '01 Z28 Knock Sensor Code
    By David Ray in forum General Help
    Last Post: 05-03-2009, 10:31 AM
  5. Knock Sensor Low input code
    By clayton006 in forum General Help
    Last Post: 07-05-2007, 11:37 AM
