Thread: Torque arm
05-16-2010, 10:23 AM #1
Torque arm
So I take my mom out for her birthday this morning first time I have been able to bring her for a ride in the TA and I hit a bump all of a sudden something is banging under my center con so I pull over look under the car, rock the tire and sure as shit my torque arm is not connected to the trans anymore. I don't know if it broke or the bolts just backed out. I did the clutch last year and now I wonder if me or my buddy torques them or just tightened them. I just hope it didn't break the tranny case. What do I do if it did????
05-16-2010, 11:28 AM #2Exalted Cyclops
- Feb 2007
- San Diego, CA
If it broke the tailshaft then you'll need to replace it. Simple as that.
While you're at it (provided you've got the $$$) replace that flimsy stamped POS TA and get an adjustable one, preferrably a body mount one so you don't break that new tailshaft again.
BTW, just so you don't think I'm calling your Trans Am a "flimsy stamped POS" (hmmmm, now that I mention it...), "TA" is internet shorthand for Torque Arm.
05-16-2010, 12:10 PM #3
Agree. It is best to get that off the back of your transmission anyway. Hopefully, you didn't do any damage to the tailstock, it's an easy swap if you did break it though.
05-16-2010, 05:04 PM #4
Thanx guys.... And I would like to get a new TA I would prefer one that is body mounted maybe with a drive shaft loop...
If I did break the tail stock what do I have to do to swap it out
05-17-2010, 01:51 PM #5
i have my body mount adjustable ta with driveshaft safety loop and love it. just noisey thats all. tailshafts arent hard to replace
05-17-2010, 03:58 PM #6
got under it today and it was the very top bolt that worked its way out and let the TA come out now to buy a new mount....do i need the lip facing towards or away from drive shaft????? i just hope the bracket that the mount sits in isnt damaged
05-18-2010, 07:54 AM #7
You otta invest in a torque arm relocation kit to get it off the trans
05-18-2010, 08:49 AM #8King 0f n00bz
- Jan 2006
- Shepherd, Michigan
yup thank you!!!
when it comes to T/As you really need to know what your goals for the car are.....if you are DD your car a lot.....you do not want a short arm T/A (aka body mount) they will transmit a good amount of road noise ........if you drag...then go get em tiger and run a short arm T/A ....i think a better choice for 75% of drivers is a long arm T/A with a relocation bracket ..mind you it will still be noisier than a trans mount...but it will be more tolerable. I personally am going to go with a short am ..but i am also going to fab up some type of rubber bushing to go in between the mount and the floorboard to absorb some of the noise/vibration
which torque arm to go with...
By goof4080 in forum Suspension and HandlingReplies: 13Last Post: 03-12-2012, 09:48 PM -
For Sale: umi tunnel mount torque arm brace and on car adj torque arm
By 99yellowz28 in forum Parts For Sale / TradeReplies: 3Last Post: 07-10-2011, 08:33 AM -
Torque Thrust II's vs Torque ThrustM Chrome's??
By SteelmanLS1 in forum Wheels and TiresReplies: 5Last Post: 03-01-2008, 03:36 PM -
WTB Torque arm....
By clg82 in forum Parts Wanted / TradeReplies: 0Last Post: 10-30-2007, 09:55 PM -
HP vs Torque!?!
By Frankthetank in forum Dyno InformationReplies: 72Last Post: 02-25-2007, 07:24 PM
