Results 1 to 15 of 15
Thread: is this normal?
    Member dav-02ws6-m6's Avatar
    Mar 2010
    VA
    2002 trans am ws6
    is this normal?
    ok sense i did the tune-up on my car samething just doesn't feel right like for example when i take off on 1st it feels kinda jumpe and if i am driving like
    60-65 on the interstate on 6th push the gas pedal it feels the same way. it only does it when the car is running in like 1500-2000 rpms. has anybody had the same problem?
    Bragg NC
    Met. Sunset Orange
    01 SS
    Did you change the fuel filter?
    Did you replace all the plugs? Are all the wires seated fully on the plugs and coils?
    What did you gap the plugs at?
    J
    Mar 2010
    VA
    2002 trans am ws6
    yep when i did the tune-up i did all the plugs (NGK's) i first did them at .043 and just yesturday i put them at .051 i also did the fuel filter air filter (k&n) and a little valve that goes from the intake in a plastic tube to the back..
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Kinda sounds like a misfire, like one of the plug wires aren't on all the way, bad plug wire, or one of the plugs is slightly cracked
    Orlando, FL
    Mean Black
    get an ohmeter or if you have a multimeter set it to continuity check. Pull each wire out and check for resistance and/or open wire. If you have an open wire then thats your problem. If you have a wire with a huge resistance difference it could cause issues too. Almost everytime I replaced my plugs I check my wires and one is bad or has a high resistance reading. I just did my plugs and one of my MSD wires was bad at the crimp connector. i was able to redo it but I don't have any extra slack for future uses.
    Mar 2010
    VA
    2002 trans am ws6
    i am going to check the wires then because before i had replaced the plugs i didn't have this problem. i was considering on taking the NGK's out and putting the stock ones. thanks..
    Bragg NC
    Met. Sunset Orange
    01 SS
    I would first just check and see if the wires are good and tight and if they are then i would pull the plugs and check the gap on them.
    J
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Weak fuel pump?
    Orlando, FL
    Mean Black
    the 1st time i used NGK's I set a gap that I can't remember and had a bad and erratic idle. i pulled them out and went stock. I gave another try to the NGKs and i gap them at .050, no problems so far.
    North Jersey
    2004 GTO M6
    I think I gapped my NGKs at .45 when I replaced the plugs. Good so far.
    Mar 2010
    VA
    2002 trans am ws6
    ok guy problem solved it could off been one or a few things like for ex. when i gap the plugs a .051 it felt worst so i went back and took the advice i took the plugs back to .043. something that i notice was that when i was adjusting the gap i bented the tip on a few plugs. so i fixed that i also checked the wires one of them didn't look very good or bad so i changed anyways. Now it's working like the day i bought it. The cool part is that now it only takes me like 30 minutes to change the plugs.
    So thanks you guys for all the help.
    North Jersey
    2004 GTO M6
    Chirping the rears yet?
    Orlando, FL
    Mean Black
    glad to hear that you fix it.
    Mar 2010
    VA
    2002 trans am ws6
    yep lol i remember saying that i didn't wanted to do it again..
    Mar 2010
    VA
    2002 trans am ws6
    Thanks..
  1. Question: Is this normal?
    By Sarge91 in forum General Help
    Last Post: 04-09-2010, 05:41 PM
  2. Is This Normal?
    By bgable in forum General Help
    Last Post: 04-29-2008, 06:37 PM
  3. Is it normal...?
    By 1MileCrash in forum Manual Transmission
    Last Post: 04-11-2007, 07:02 PM
  4. Is this normal?
    By {FzS}BlacKMagicK in forum General Help
    Last Post: 02-23-2007, 02:50 AM
  5. normal?help
    By 01SOMSS! in forum Internal Engine
    Last Post: 01-20-2007, 11:04 PM
