Thread: texas speed 215 cnc heads
05-14-2010, 03:49 PM #1Junior Member
- Mar 2010
- ofallon mo
red- 02 ss camaro
are the texas speed 215 cnc heads anygood ?
05-15-2010, 06:26 AM #2Member
- Jun 2009
- coon rapids, MN
red- 2000TA
how much?how much flow.
05-15-2010, 08:20 AM #3Junior Member
- Mar 2010
- ofallon mo
red- 02 ss camaro
at .600" 318cfm intake flow 238cfm exhaust flow
05-19-2010, 12:47 PM #4Member
- Mar 2007
- NC
NBM- 1998Z28
05-20-2010, 02:23 PM #5Junior Member
- Mar 2010
- ofallon mo
red- 02 ss camaro
not throwing rock just looking for feedback from someone who is familiar with Texas Speed heads Thanks
05-22-2010, 05:51 PM #6
well consider this stock LS1 heads flow 243 intake at .600 and right around 182-194 exhaust.
stock ls6 heads flow 278 intake at .600 and between 208 and 222 exhaust
now mind you this is on bare heads, numbers will change with porting.
Example:
ported LS1 heads with a stock ls intake are 258 intake at .600 and around 193-206 exhaust
now those same heads with an LS6 intake are 283 intake at .600 and around 212-226 exhaust
ported LS6 heads with an LS1 intake are 268 intake at .600 and around 201-214 exhaust
now those heads with LS6 intake are 289 intake at .600 and around 216-231 exhaust
for a good power producing head you exhaust cfm will be between 75-80% of the intake cfm those heads you are asking about are at 75% exhaust flow.
once again these numbers will change depending greatly on what intake you run whether or not those flow numbers they have listed are on a bare head or tested with an intake and if so which one LS1, LS6, Edelbrock, F.A.S.T etc. Hope this helps a little.
05-22-2010, 07:47 PM #7Member
- Jun 2009
- coon rapids, MN
red- 2000TA
different shops flow heads differently.some use a pipe on the exhaust ,some don't.are the TSP 215 cnc heads stock gm casting? or are they cast for TSP?
05-24-2010, 12:09 PM #8Member
- Mar 2007
- NC
NBM- 1998Z28
TSP 215s are not factory castings and flow alot better than the heads I have on my car. They are like the top of the line,top dollar AFRs and Trickflows for people trying to squeeze out the last little bit of hp possible. However I do like my TSP heads. But the old saying is true You get what you pay for!
My heads flow
TSP LS6 2.5 CNCED PRCs
LIFT INT EX
.200 147 114
.300 209 152
.400 258 191
.500 294 207
.600 316 226
and the 215s flow way better than mine.Last edited by PFM; 05-24-2010 at 12:18 PM.
TSP 347 SB, TSP Stage 2.5 PRC LS6, TSP MS4, Performabuilt Stage 2 4L60E, Yank PT4000, 4.11s, Fast 90/90, FTRA Cold air intake+all the free mods, Dynatech Supermaxx Exaust System, DMH Cutouts, Hooker Catback/FTRA Tips. Tuned by RPM/Garner NC. 11.28@119
05-25-2010, 06:30 PM #9Member
- Jun 2009
- coon rapids, MN
red- 2000TA
get them if you can afford them.you need good heads to make great power.the better the head the less cam you need .dose TSP offer the 215 cnc head with a cam kit?
texas speed prc215 cnc heads
By markfs in forum External EngineReplies: 1Last Post: 05-15-2010, 09:16 AM -
Texas Speed
By 01ws6er in forum Sponsor FeedbackReplies: 6Last Post: 01-13-2009, 10:52 AM -
texas-speed.com
By blackhawk01 in forum Request and FeedbackReplies: 12Last Post: 12-29-2007, 11:32 PM -
ls1 texas speed cam.
By chad2000ss in forum Parts For Sale / TradeReplies: 11Last Post: 04-08-2007, 06:40 PM -
Texas Speed 233/239 Cam?
By wesTXwitesnake05 in forum Internal EngineReplies: 0Last Post: 11-05-2006, 06:40 PM
