Results 1 to 14 of 14
05-14-2010, 06:46 AM #1
do I REALLY have a 2 series Carrier?
I pulled off the diff cover at work yesterday and was going to start my gear swap/overhaul, but before I took the carrier out I noticed the pinion gear that was installed was a lot larger than the 3.73's I was going to swap in. I know my car has 2.73 gears because I have seen the build sheet and the car cruises at 1500 RPM's between 60 and 70 mph.
I also emailed ws6store.com (Very Helpful and quick responses BTW) and verified the part number. I have the correct gears for a 2 series carrier.
so does this sound like I have the right gears?
05-14-2010, 07:45 AM #2
The new ring gear should be a lot thicker than your stock one. The higher numerical ratio moves the ring gear teeth closer to the pinion as it is smaller in diameter. A 3-series carrier would have different backspacing to make up for this offset, so a thicker gear is not required. Sounds like they got it right for a 2-series carrier.
05-14-2010, 09:38 AM #3
ok thanks. it just threw me off by the big size difference. I knew going from 2.73 gears to 3.73's would be a big difference, but not this big.
05-14-2010, 10:11 AM #4
You can take a rough measurement to check it. Pinion centerline to face of carrier (back of ring gear) should be identical on both sets. Lay your new ring gear on a flat surface and have someone hold the pinion gear horizontal to it with the teeth engaged so you can take a measurement of the new set.
05-14-2010, 03:44 PM #5
ok i'll be checking all this monday on my day off.
05-14-2010, 07:29 PM #6Member
- Jun 2008
- Euclid,ohio
Black- 1998 Z28
for reference
05-15-2010, 07:05 AM #7
^^ Good info. Thanks for posting it.
05-15-2010, 08:58 AM #8
Its been in the sticky up top the whole time also
05-15-2010, 10:18 AM #9Senior Member
- Apr 2008
- Madison, WI
might as well throw this picture in here from the same sticky
05-15-2010, 02:10 PM #10
05-15-2010, 02:37 PM #11
sorry. I was in a hurry. I thought this cant be the first time someone asked this question
05-19-2010, 08:44 PM #12
ok so I got the gears installed and I am extremely happy. I am still only at 2200 rpms at what I think is 65 mph (no tune to fix the speedo yet). I am thinking I should have went with 4.10's, but o well I am still happy. the ring gear was MUCH thicker to make up for the difference in pinion gear size like stated above.
thanks for all the help.
05-20-2010, 12:27 AM #13Member
- Jun 2008
- Euclid,ohio
Black- 1998 Z28
2.73 upgrade to 3.73 is the general consensus recommended gear mod. ENJOY !
05-20-2010, 06:51 PM #14
I love the added kick in the ass. I cant wait to see what its like after I get the built transmission tuned and get the speedo corrected. I can tell its having problems figuring out what to do since the speed is off.
For Sale: 3.73 gears (take-off) for 3 series carrier
By Mean Green Z28 in forum Parts For Sale / TradeReplies: 6Last Post: 10-28-2009, 06:40 AM -
series 2 carrier vs. series 3 carrier
By 02transamce in forum DrivetrainReplies: 1Last Post: 02-09-2009, 05:16 PM -
2 series carrier with spacer?
By FORMULA7 in forum DrivetrainReplies: 2Last Post: 02-22-2008, 01:49 PM -
4.10 gears 7.5 GM 3 series carrier
By SSmaro in forum Parts For Sale / TradeReplies: 16Last Post: 04-17-2007, 05:42 PM -
wanted 3 series carrier
By shady1504 in forum Parts Wanted / TradeReplies: 1Last Post: 11-26-2005, 03:27 PM
