Results 1 to 20 of 21
Thread: connected battery backwards
05-11-2010, 08:44 AM #1Junior Member
- May 2010
- czech rep.
black- 1996 impala ss
Hi, I connected battery backwards on my Chevy Impala SS 1996. Shortly after that I disconected it, It smoked from alternator, but it was OK, The engine is running but it is rich as hell. Idle and high RPM is somehow ok, but bewen there is a gap where it has no performance. Anyone knows what could be wrong?
Thanks for any advice!
05-11-2010, 08:45 AM #2its short but its skinny.
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
hmm..is the service engine light on? if so have it checked out..could have screwed somethin up in the alternator....i know lack of voltage can really effect performance...otherwise drive it around for a while and see if it clears up.
05-11-2010, 08:56 AM #3King 0f n00bz
- Jan 2006
- Shepherd, Michigan
more than likely you fried the alt. and a few sensors .....if the alt is flaky it will effect the sensors readings and such.
05-11-2010, 12:02 PM #4Junior Member
- May 2010
- czech rep.
alternator seems to be all right, no check engine light and diagnostics didn't recognise any bad sensors. When it runs it is all insane. Speed 180km/h, temperature -68°C and so on. But the scan can't find any errors.
05-11-2010, 12:37 PM #5
05-11-2010, 01:57 PM #6
I've never ran into any of this before but I would probably try to pull the batt. and pcm fuses and let it sit for a few minutes and see what that does.
05-11-2010, 02:11 PM #7
Power chip is cooked. Replace the ECM, your current one is prolly in limp mode. Changing the chip may help but most likely the FET's took the hit and are cooked now though. Best to replace the whole unit..imho
09-07-2010, 11:36 PM #8Junior Member
- May 2010
- czech rep.
OK, the alternator is cooked, anyone know where to find a bridge rectifier for less then 100 bucks?
09-07-2010, 11:40 PM #9Junior Member
- May 2010
- czech rep.
The ECM was OK, You know what wasn't? the water temperature sensor. When removed, it started to act like a car!
09-08-2010, 03:39 AM #10
09-08-2010, 04:06 AM #11
09-08-2010, 06:00 AM #12Electrical Engineer
- Jul 2009
- North of the Motorcity
+3. Just like you Smittro, I was thinking the ECU would be fried from back feeding... well... everything.
Bridge rectifier for the voltage regulator? I know you can buy them all over the place, I but think you have to replace the whole regulator? Or the alternator is good now?
09-10-2010, 11:52 AM #13Junior Member
- May 2010
- czech rep.
You know the car was sitting in a barn for a few years, so there is a way, that the coolant temp sensor was done already before the polarity mistake. And it took a few seconds, I acted quickly when alternator smoked. But yeah, I believe the diode trio is cooked and that's what need. But You see, I'm from Europe and there is no such thing as a hevy duty 140 amp alternator :s...We don't have these lying around...So I need some decent store with alt. parts or something...
09-10-2010, 11:59 AM #14
09-10-2010, 10:45 PM #15Junior Member
- May 2010
- czech rep.
Yeah, but alternatorparts is not willing to do bussiness, rockauto does have a good manners but bad price for rectifiers, it is better to buy new alternator. But that's hundred for the alternator and hundred for the shipping. And that's the base for duties.
Do You think that 96' impala ss does need 140 amp hevy duty alternator? I mean shouldn't 75amp be sufficient enough?
09-11-2010, 09:46 AM #16
I believe the SS cars came with the police/taxi package. Generally those packages come with a heavy duty high amp alternator to cover the added load like lights and radios and so forth.
75amp should be fine, though for me what comes out is what goes in parts wise.
09-12-2010, 06:07 AM #17
09-12-2010, 06:43 PM #18
100 for shipping!?!?
where ya live the moon? lol that's crazy you should be able to get a new setup shipped to your door for far less.. wow I've have egay metal suppliers that ship in weights far higher than an alt. that don't charge 100 bucks for heavy metal stock.. Keep lookin' bro..
09-13-2010, 10:43 AM #19
09-13-2010, 11:14 AM #20
Does anyone else think this is half ass backwards
By blackSS01 in forum Almost Anything GoesReplies: 17Last Post: 10-03-2012, 12:37 PM -
wanted antenna with mast connected
By jesseheel in forum Parts Wanted / TradeReplies: 0Last Post: 11-23-2008, 07:30 AM -
Modified CAI connected to a hood scoop?
By xinthenight in forum External EngineReplies: 0Last Post: 06-27-2007, 08:17 PM -
Are You Connected?
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 11-21-2006, 03:47 PM -
engine dies when alternator is connected
By RAT454 in forum General HelpReplies: 0Last Post: 09-04-2006, 10:31 AM
...that may have something to do with it
.. I'd keep looking..
