Results 1 to 10 of 10
05-10-2010, 01:03 PM #1
Headlight issue....possibly electrical?
Hello everyone,
SO, everytime I engage my alarm (on or off) the headlights flip up, then down, and the passengers side light makes this extreme clicking sound...as if it wasnts to close more than it can...a tktktktktktktktktk sound...
Coincidentally, the heallight went out too...so I'm probably gonna go and swap it tonight...
My question is, to the best of your guys' knowledge...has anyone had this issue before? Or can you maybe suggest a course of action to remedy this?
Thanks in advance for your help.
05-10-2010, 01:46 PM #2Senior Member
- May 2009
- college station, tx
sold: 1999 firebird- 1998 Trans Am
it's common, dont fear someone will help you out, theres alot of people here who have delt with it
05-10-2010, 04:10 PM #3
gear in you headlight motor that raises and lowers the headlight is stripped there is a website that a guy makes and sells the aluminum replacement gears that will fix the problem indefinatly (spell)
05-10-2010, 05:05 PM #4
05-11-2010, 07:15 AM #5Member
- Tulsa,OK
Quick Silver- 2002 Z06
Try solution 1 first. It ALWAYS works as long as it has not been done already.
I personally have had some bad luck with the metal gear, my epoxy has not always held up for much more than a year or so and I also had a motor die.
Hind site, all the time and effort I spent in taking the motor apart and what not.. Might as well just replaced it with a new one
Just me though, tons of people have done the metal gear.
Camaro Owners Click Here
Firebird Owners Click Here
www.AutoTrix.net
05-11-2010, 12:28 PM #6
I just replaced my right one, by the way that is the exact thing that mine did when the motor died. Bought one at Auto Zone for $70, lifetime warrenty.
05-12-2010, 07:51 AM #7
Thanks guys for all the responses. They helped a lot. Cheers.
05-12-2010, 08:54 AM #8
I had the excat same problem with mine. classic industries sells the brass gear kit for like $50.00 i replaced both of them on mine have not had a problem yet. I tried the plastic gear swap frist it worked for me for like 2 months it is a temp fix
05-12-2010, 08:59 AM #9Member
- Tulsa,OK
Strange it only lasted for 2 months. I have both stock motors on my headlights (one with the 180* swap) on my 98 with over 200,000 miles.
I think the key to keeping them good is how you use them. Changing the metal gear does eliminate the need to pay any attention.
Here is my rules for me and my wife that keeps them in perfect working order.
1. Never turn the headlights on while going 30+mph. Try to always turn them on when stopped. When you are moving, air slams the headlights up helping strip the gear.
2. Sometimes you get in your car and instinctly reach to turn the headlights on then realize what you have done and throw the switch back to off. Don't do that! Wait for them to come all the way up THEN turn them back off.
I promise making sure you do these things will make sure your factory plastic gears never fail.
05-12-2010, 11:46 AM #10
Electrical Issue
By Kicker806 in forum General HelpReplies: 11Last Post: 09-23-2013, 06:41 PM -
Help: Need some help on an electrical issue
By Stephens 94 Z28 in forum Stereo and ElectronicsReplies: 4Last Post: 08-21-2013, 04:24 PM -
electrical issue i think
By Ieatstangs in forum General HelpReplies: 11Last Post: 03-22-2011, 06:57 PM -
Help: Electrical problem? Headlight/signal issue
By onetroubledguy in forum Firebird / WS6Replies: 23Last Post: 01-20-2009, 08:53 PM -
Electrical Issue
By McCool318 in forum Stereo and ElectronicsReplies: 4Last Post: 07-24-2008, 01:15 AM
