    Member camaroluvr447's Avatar
    Sep 2009
    Steubenville, Ohio
    2000 Pewter Z28 M6
    Lucas or Marvel to Lube in High RPM??
    So i was mashing on the throttle the other day realized my z has 101,000 on her and I know ls1's are good high mileage engines but I still worry sometimes. My question is what lubricant can I add to the engine (or possibly a 2-cycle oil to the fuel to lube some internals) to keep down wear in a high rpm scenario? My concern with lucas is that it thickens and may slow/prevent the proper oil flow, whereas Marvel may thin the oil and reduce its lubricating properties.
    I know this is a well debated topic, but just want to know firsthand what your opinions are!
    Also any ideas to reduce heat would be great!
    Wisconsin
    2001 Camaro SS M6
    Don't waste your money or your time with that crap. Just run a good oil like Pennzoil Platinum or Amsoil and a good Ac Delco filter/WIX and you will be fine. Keep it topped off and not low
    ┌∩┐(◕_◕)┌∩┐
    wouldn't want to fight them!
    Wisconsin
    2001 Camaro SS M6
    If you are really that worried with heat you could do an Engine oil cooler but there really is no need
    sick & twisted SS 02_slp_ss's Avatar
    Jun 2009
    Chambersburg PA
    2002 SS camaro
    Quote Originally Posted by camaroluvr447 View Post
    i use the lucas, it works great for me i like it. i run it in my pickup, 4wheeler, an semi i love it
  1. Question: Marvel Mystery Oil in Gas/Oil in the LS1
    By camaroluvr447 in forum Internal Engine
    Last Post: 10-07-2009, 08:27 AM
  2. marvel mystery oil...
    By jray0305usa in forum Internal Engine
    Last Post: 03-05-2009, 06:26 PM
  3. Oil & lube
    By Blackout01 in forum General Help
    Last Post: 05-23-2007, 08:56 AM
  4. Lube Job??
    By thugtilidie18 in forum General Help
    Last Post: 05-22-2007, 10:20 AM
  5. Lucas Oil
    By SR71 in forum General Help
    Last Post: 09-28-2006, 07:00 AM
