Thread: 4l60e not going into gear?
05-08-2010, 10:25 PM #1Junior Member
- May 2010
- Denver
pewter- 2000 b4c ls6 Camaro
Ok just did a full ls6 swap in my 2000 Camaro Z28. Car starts right up and all the wiring is GOOD to the trans til i try putting it into "R" "D" "3" "2" "1". I get nothing. Park works but its not wanting to go into gear and move. Anyone had this happen or know what it might be?
05-09-2010, 04:34 AM #2Senior Member
- Apr 2008
- Madison, WI
I have had that happen before. Either there isn't any fluid in the pan, no filter in the pan, or you didn't bolt the torque converter to the flexplate.
05-09-2010, 10:11 AM #3Junior Member
- May 2010
- Denver
05-09-2010, 02:14 PM #4Senior Member
- Apr 2008
- Madison, WI
wait...did you put the bolt the torque converter to the flexplate and then install the transmission??
05-09-2010, 02:59 PM #5Junior Member
- May 2010
- Denver
05-09-2010, 05:30 PM #6Senior Member
- Apr 2008
- Madison, WI
yikes...thats your problem. You are supposed to put the converter into the trans, spin it around and seat it into the transmission pump lugs. Then install the trans to the engine, then bolt the converter to the flexplate.
I've seen broken pumps as a result of using your method.
05-09-2010, 11:16 PM #7Junior Member
- May 2010
- Denver
05-10-2010, 02:44 AM #8Junior Member
- Apr 2010
- georgia
- 2002 camaro ss
That is a waste of time. I am sure it has broken the pump rotor and slide. I would go ahead and pull the pump out and replace the rotor, slide and veins.
Help: 4l60e First gear problems
By Gerbil21 in forum Automatic TransmissionReplies: 9Last Post: 08-20-2016, 09:23 AM -
Help: A4 4l60e Trans won't shift out of 1st gear
By CobraKilla in forum Automatic TransmissionReplies: 12Last Post: 07-02-2012, 07:02 AM -
Are gear ratio's fixed when building 4l60e or 4l80e
By Intrepidman in forum Automatic TransmissionReplies: 8Last Post: 02-11-2011, 07:11 AM -
Help: 4l60e died 1st gear no reverse bad whine sound
By nerisls1 in forum DrivetrainReplies: 8Last Post: 03-02-2009, 01:58 PM -
4l60e 4x4 1st gear issues
By 96tahoe4x4 in forum Automatic TransmissionReplies: 7Last Post: 04-19-2007, 06:46 AM
