    Memphis,TN
    2001 Z28 Camaro
    Auto Tranny Problem
    I am having this problem with my transmission when my car upshifts into 2-3 and sometimes 3-4 the car starts acting like it can't shift into a higher gear kinda feels like someone pulling the car backwards or a shudder from the front of the car. It became worser today on my way home only way I can upshift through those gears if I keep the rpm's below 2000 or above 3000. Is the Transmission slipping, what is the problem and how much will it cost to get it fixed?
    Member SR71's Avatar
    Irving, TX
    1998 Trans Am, 2007 TB SS
    Sounds like the clutchpacks are going. If you wanna go "cheap" first, you can try a fresh flush and filter change. Sometimes it helps. Might wanna take it to a shop and have it checked out.
    Irving, TX
    Could be a solenoid as well. I'm going through some tranny problems right now as well, so I can understand some of the frustrations. Good Luck.
    Memphis,TN
    2001 Z28 Camaro
    Ok took it to two shops today and one told me i needed a tune-up because it feels like the wires went bad and the second shop (a more Known shop) told me that i had engine misfire and transmission was slipping, they told me a tune-up would get rid of the engine misfire and i need a new transmission in order to fix the problems, would cost me $2100.00 for everything. is that a good price?
    Irving, TX
    If that includes the new transmission and labor, yes it's a good price. Are you getting a new one, or are you getting your old one rebuilt?
    Irving, TX
    (sorry for the back to back posts)
    Now, I have heard of bad wires disguising themselves as a bad tranny. Start out cheap, get the wires changed first and see if that helps. If not, then start looking at transmission shops. Wires are 50 to 70 dollars for our cars -- a new tranny 1200 to 2000. Good luck man.
  1. Auto tranny Mounts?
    By 89RS&98Z28 in forum Drivetrain
    Last Post: 05-11-2012, 08:16 AM
  2. Replies: 5
    Last Post: 01-28-2008, 01:48 PM
  3. C5 auto tranny?
    By 1BADSSUV in forum Corvette
    Last Post: 12-27-2007, 09:42 AM
  4. Auto Tranny Help!!
    By GULLETT17 in forum Automatic Transmission
    Last Post: 12-26-2007, 10:53 AM
  5. 96 Camaro Auto-Tranny Problem
    By Raven81 in forum Automatic Transmission
    Last Post: 07-10-2007, 08:07 AM
