View Poll Results: Which is better auburn or eaton lsd
- Voters
- 3. You may not vote on this poll
auburn lsd
0 0% -
eaton lsd
3 100.00% -
equal
0 0% -
other
0 0%
Results 1 to 3 of 3
05-04-2010, 07:59 AM #1Junior Member
- Jul 2009
- hendersonville,tn
White- 1998 trans am
Which is better auburn or eaton lsd?
05-04-2010, 08:16 AM #2
If this is going in a 10 bolt don't do it, save your money.....then by a 12 bolt or 9". I think Eaton is better, just personal experience.
05-04-2010, 09:11 AM #3
I've avoided the Auburns for years. It used to be.....
They are a cone design, and are not rebuildable. Although Auburn offers a rebuild service for these, it's nothing more than machining the case and adding shims for preload. Not the best. They rely on the case for preload on the coans, once the case wears, it's done.
Maybe they have changed designs since, but I haven't used one in years.
I've used Eaton for many years. They were the manufacture for all the GM posi's throughout the 60's and 70's. They are a clutch design that uses springs for preload. The nicest feature, is that they are rebuildable later down the road. You can change the clutch packs, many different materials are offered, as well as change the spring rates for various preload settings. Basically you can tailor the setup to your preferance. The rebuild kits are still available from several suppliers.
Eaton 112?
By predator in forum External EngineReplies: 0Last Post: 03-10-2008, 10:26 AM -
Auburn-LSU
By Y2KPewterSS in forum Almost Anything GoesReplies: 6Last Post: 10-21-2007, 11:43 AM -
Auburn vs. USC
By BadBlueBird* in forum Almost Anything GoesReplies: 6Last Post: 09-29-2006, 04:58 PM -
#6 LSU v #3 Auburn
By gwballin in forum Almost Anything GoesReplies: 41Last Post: 09-17-2006, 09:47 AM
