Results 1 to 11 of 11
Thread: cutting out
05-02-2010, 04:03 AM #1Member
- Aug 2006
- canada
bright rally red- 2002 ss 35th
cutting out
my 02 35thle seems to be missing or cutting out at idle speeds; and also when going to give it gas at low speeds it feels choppy and then it smoothes out. thanks for your help great site.
05-02-2010, 05:09 AM #2
Is it throwing any codes? If so, post them up or check the code list under the "General Help" stickies.
Otherwise, the first thing I would do is clean your MAF and IAC. You can buy a specialized MAF cleaner made by CRC at just about any parts store. If you utilize an oiled cotton gauze air filter (ie. K&N) they are known to contamintate the MAF sensor wires and cause problems. Let us know what you find.
05-02-2010, 06:04 AM #3Member
- Aug 2006
- canada
no check engine lights have come on yet.. the last time i cleaned the maf was late june 2009. im going out now to see if it drives anybetter. maybe the problem is from it sitting all winter ive only driven it 3 times since out of storage..
05-02-2010, 06:20 AM #4Senior Member
- Apr 2008
- Madison, WI
yeah maybe you should run through a tank of gas and get some fresh gas in there.
05-02-2010, 08:32 AM #5Member
- Aug 2006
- canada
filled it up yesterday suncoco 94 octane; almost halftank now still is choppy same symptons....
05-02-2010, 09:14 AM #6
Still no codes? How about a vacuum leak -- maybe the PCV system where it plugs into the intake?
05-02-2010, 09:24 AM #7Member
- Aug 2006
- canada
05-02-2010, 09:24 AM #8
05-03-2010, 02:42 AM #9Member
- Aug 2006
- canada
05-10-2010, 09:38 AM #10Member
- Aug 2006
- canada
hooked the scanner to it today... no codes whatsoever my mechaninc is saying it could be a bad plug... he also said try some fuel injector cleaner..
05-20-2010, 10:44 AM #11Member
- Aug 2006
- canada
hooked the scanner again today and got misfire cylinder# 2... i think the code was something like p0302... took the wire off tested for resiatiance took the plug out it looked like it had a lot of carbon deposit on it cleaned it put it back in the car ran alot better.. also checked for fuel pressure it was between 58-60.. so now where going to change all the plugs.. i just had the plugs changed not even a year ago and there already bad..
99 TA .....Cutting up whole car
By chadk in forum Parts For Sale / TradeReplies: 35Last Post: 11-10-2008, 10:46 AM -
cutting out ?
By boofthese in forum General HelpReplies: 5Last Post: 09-10-2008, 05:33 PM -
cutting out the cat?
By ATCharming in forum External EngineReplies: 8Last Post: 03-27-2007, 10:56 AM -
Cutting Out
By nmhellraiser in forum Internal EngineReplies: 7Last Post: 03-11-2007, 10:22 AM -
car cutting off
By iceman504 in forum General HelpReplies: 0Last Post: 12-15-2006, 05:15 AM
