02-27-2006, 03:42 PM #1Junior Member
- Jan 2006
- San Diego
White- 1998 Camaro Ss
sqeak noise when steering HELP! :(
hey fellas
lately my car had some killer noise while steering plus the p/s steering resvoir was leakin so i had the p/s pump and resvoir changed but for some reason it still makes the noise only when im driving though if im at a dead stop and i turn the wheel no noise only when im drivng do i hear it.. so im thinkin maybe my rack n pinion is goin out? or after the resvoir leakin for so long did it damage something ?
any help would be good thx in advance
02-27-2006, 04:00 PM #2
try reving the car up and holding it at like 2-3k and then turning the wheels at a stop, that will tell you if it is a pump or pump componet, because at a moving pace your rps are naturally higher than at idle,
if that doens make the noise it is probably something like your rack and pinion or linkage, just my thoughts i could be wrong
02-27-2006, 05:43 PM #3Junior Member
- Jan 2006
- San Diego
thx for the info bro im gonna try that! any other ideas ?
02-27-2006, 06:20 PM #4
if you replaced the pump and it still makes noise, then most likely the rack and pinion is crapping out on you as well. which is causing the pump to make noise because of the elevated pressure.
New power steering pump making subtle noise?
By Ws6islife in forum General HelpReplies: 20Last Post: 02-28-2013, 01:45 PM -
Help: Knocking noise when steering camaro
By torker in forum Suspension and HandlingReplies: 9Last Post: 02-24-2012, 04:59 PM -
Knocking noise from steering
By TiGer85SS in forum GM TrucksReplies: 5Last Post: 06-10-2010, 03:24 PM -
Hearing A Noise.... Power Steering Pump?
By KyleLs1 in forum General HelpReplies: 7Last Post: 08-03-2007, 04:02 PM -
Noise in steering joint
By lynx10147 in forum Suspension and HandlingReplies: 1Last Post: 11-17-2006, 03:47 AM
