Results 1 to 14 of 14
    Member RedSmokey's Avatar
    CA (sacramento)
    F250
    Tire and wheel size question
    Would a Nitto NT555 in a 245/40/18 fit ok on a 18x9.5 wheel for the front of my 2000 z28?
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    Quote Originally Posted by RedSmokey View Post
    no. nittos run small so you would be looking at a 235 or 240 ..and that is pushing it for stock 16"s
    CA (sacramento)
    F250
    yea, I kinda figured it would be to small, but wanted to double check. I also didnt know nitto's ran small. Thanks!
    Auto Painter RyanJM's Avatar
    Houston, TX
    I would go a little wider with that rim width. I run 245/40/18 BFG KDW NT's and before that Kumho Ecsta ASX's on the front but I'm running a 18x8.5 rim.
    My 18x10 rear I run a 275/35/18
    1998 Trans Am 85k miles.
    02 Trailblazer -Sold
    09 Ram 1500 CC - Sold
    09 Cobalt SS/TC - Sold
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    9-9.5" wheels need a minimum 275 size tire
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    CA (sacramento)
    F250
    Quote Originally Posted by RyanJM View Post
    I was just asking so i could get a tire on the rim till i buy new (found close to free used pair) but i will just buy some new ones.
    Just going to go with some 275/35/18 all the way around Thanks for the info guys!
    Coral Springs, Fl
    Sunset Orange Metalic
    Quote Originally Posted by 9T8W66 View Post
    I've got 245s on the front of my car (9" wheels) and they fit fine. Nittos do run smaller but they will fit. Would still go bigger with nittos though.
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    narrowest I ran was 255's on a 18" 9.5.
    I would like to know the measurements between nitto's and other brands. I measured some 275 nt555's and some continental 275 at the point of tread contact and both looked to be at 10" road contact. Tool used to measure is designed to measure wheel width for tire balancing so not as inaccurate as using a tape measure.
    Coral Springs, Fl
    i always heard all nittos run smaller, even ordinary 555s
    Join the PHK @ thephk.org Sommer86@6LE's Avatar
    Studio City, CA
    I'm running 285/35/18 Nitto 555R's and Michelin Pilot Sports on my 18x9.5 spyders. No rubbing, and tires looks great!
    Join the PHK
    2009 LS1.com Calendar Car
    CA (sacramento)
    F250
    Quote Originally Posted by Sommer86@6LE View Post
    Whats the offset on your wheels if you dont mind me asking
    Studio City, CA
    My offset is 57
    Member SS201's Avatar
    Apr 2009
    SW KANSAS
    2002 Chevy Camaro SS
    I just got some Nitto 555R , the extreme drag radials for street. They're on a set of 18x10.5 wheels, the tire size are 305/45/18. They did rub a little with the wheel well and rear bumper but I got it fixed. I do not recomend that yo get 45's they are just too meaty!. But the 305's do fit just fine, with the exception of the bump stop on the rear axle.
    Here's the link to see the pics if you are intereested:http://www.ls1.com/forums/showthread...=134246&page=2
    CA (sacramento)
    F250
    My offset is 57
    Awsome, thanks! My new wheels are 57 offset 18x9.5 on all 4 so they should fit great
    Quote Originally Posted by SS201 View Post
    Thanks, im going with 275/35/18 on all 4. Those do look meaty but pretty sweet. I would just get your car a little lower so they are tucked in the wheel well a little better. Clean SS though man. And as for me, i just put on LCA relocation brackets and adjustable LCA last night, so bumper rubbing shouldnt be an issue for me. Now to just find the time to get my new struts/shocks and strano springs on.
  1. Wheel/Tire Size
    By JOHNNY59 in forum Wheels and Tires
    Last Post: 07-24-2009, 12:51 PM
  2. what the best tire size for a 18x10.5 wheel
    By SexyTransAm in forum Wheels and Tires
    Last Post: 03-23-2009, 05:10 PM
  3. 18x10.5 wheel...best size tire??
    By schrysler in forum Wheels and Tires
    Last Post: 03-20-2009, 02:36 PM
  4. What size wheel should i use for this tire...
    By william SS in forum Wheels and Tires
    Last Post: 03-08-2008, 11:36 AM
