Results 1 to 15 of 15
    Senior Member
    Toronto
    SOM
    2002 SS
    What springs to use with 1.85 Rockers STOCK LS1??
    My Z has 125k miles on it so the springs are definitely tired anyways. I picked up some 1.8 roller rockers and want to put them on soon. What replacement valve springs do you guys reccomend? Any GM springs? I think i read ls6 springs would work? I read crane reccomended changing springs even new stock springs since these rockers would cause float. I know I need stiffer but how much??
    If anyone has done the mod would be cool to know what length pushrods too. These are the Crane 1.8 full roller rockers.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    Quote Originally Posted by 5abivt View Post
    why did you change ?
    Shepherd, Michigan
    98' trans am
    you know you will now be limited on your cam selection as you have increased the lift and now valve clearance will be a concern on anything not stock. what you should have done, is go with harland sharp stock 1.7s and got the comp cams 918 springs..to keep your stock geometry.
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    Comp 26918's will work ! Stockers will float out quicker with the 1.8's...
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    COMP 26918 or PAC 28-1518 would work nicely.
    Build in progress...
    Chowchilla CA
    2001 Z28
    It will work
    I am running the Crane 1.8s with the full pushrod package, Z06 cam, and Comp 918s. No problems, great daily driver. 11.95@114.
    Senior Member
    Toronto
    SOM
    2002 SS
    Very cool. so 918s seem to be enough then? Are they single beehives? i'll have to dig into it. I wont be putting a cam in this sucker. if I ever do , it will be a 400+ ci buildup so I can go back to stock then. For now this is a much more cost effective mod than a mild cam. labor quotes I got with all the associated parts for a cam swap are rediculous vs installing 1.8s.
    Chowchilla CA
    2001 Z28
    I did the rockers first, then the cam and springs. They are single beehive, it is time for new springs anyway.
    Senior Member
    Toronto
    SOM
    2002 SS
    Very cool. Going to find out about 918s and some pushrods. 114 mph is smoking for a bolt on!! Have head work too?
    Chowchilla CA
    2001 Z28
    The pass was a one shot wonder. Long tubes, 4400 stall, street slicks. I have the shorties and cats back on now, and the stock stall. Lots of other bolt-ons, an electric water pump etc. I would be lucky to get into the 12s now. It was one try to say I have an 11 second car.
    Senior Member
    Toronto
    SOM
    2002 SS
    Will these work? Ive been told 918s would be good but these sound like an equivalent.
    Patriot Performance Dual "Gold" Springs
    Patriot Performance's legendary Gold spring kit is probably the most used "drop-in" LS dual spring kit in the LS community. These complete spring consists of 16 Patriot Gold dual springs, 16 titanium retainers, 32 Super 7 Machined locks, 16 .505" ID machined spring bases, and 16 viton rubber seals. This kit will work with both stock and aftermarket rocker arms. No cutting or machining of the stock spring pocket is needed.
    *1 kit required per pair of heads.
    Part Number: 198-8401
    Technical Specs:
    Install Height: 1.800"
    Max. Valve Spring Lift: 0.650"
    Spring Pressure Closed: 135 lbs. @ 1.800"
    Spring Pressure Open: 375 lbs. @ 1.150"
    Coil Bind: 1.090"
    Retainer Material: Titanium
    Senior Member
    Toronto
    SOM
    2002 SS
    Also The 'kit' for the crane gold 1.8 roller rockers included crane pushrods. they were 7.250. Someone local is selling 7.300 pushrods for pretty cheap and theyre new in a sealed box. is .050 critical for pushrods on a hydraulic roller? I figure if 2 turns is what they call for I can go 1 3/4 since the pushrod is a tad longer and geometry should be close.
    Feb 2007
    St Thomas, PA
    That will be a good set up ! Are you getting a big cam to go with this set up ?
    Feb 2007
    St Thomas, PA
    There's a chance that you might need valve cover spacers to clear the rocker arms. Or a little work done on the inside of them...
    Senior Member
    Toronto
    SOM
    2002 SS
    No cam at all. Just rockers and freshening springs. I'll wait till I have to rebuild / freshen the bottom end then probably go heads and cam.
  1. Replies: 2
    Last Post: 06-22-2011, 05:15 AM
  2. 590 cam with stock rockers?
    By King06C6 in forum Corvette
    Last Post: 12-15-2008, 08:25 PM
  3. Biggest Computer Compatable Cam, Springs, & Rockers
    By QUIK SILVA in forum Internal Engine
    Last Post: 12-29-2006, 11:02 AM
  4. WTB: stock rockers, stock pushrods and other parts
    By jimmy 2 times in forum Parts Wanted / Trade
    Last Post: 10-31-2006, 12:20 PM
  5. NOS 5177 & SLP 1.85 rockers/springs
    By cyeagle in forum Parts For Sale / Trade
    Last Post: 10-04-2005, 09:39 AM
