Results 1 to 20 of 31
Thread: Wheel fitment?
04-19-2010, 07:36 AM #1Knight Rider
- Jul 2009
- Charleston, SC
2010 Nissan Sentra SR dd- 2001 Pontiac Trans Am WS6
Wheel fitment?
Will 18x9.5 in the front and 19x12 in the rear fit on a 2001 WS6 with stock suspension? I was also planning on lowering the car about 1.5". Does anyone know if they would fit after that drop? Also, would the wheels be two wide for the stock fenders? I know nothing about wheel fitment, lol.
04-19-2010, 09:13 AM #2
04-19-2010, 09:43 AM #3
04-19-2010, 01:57 PM #4Knight Rider
- Jul 2009
- Charleston, SC
Dang. Well the reason I ask is because I want to get this wheel set. They're 2008 C6 Z06 Sport Edition wheels. I guess I'll have to find them in a different fitment then.
http://www.c5racer.com/catalog/produ...53583b709ffd9b
04-19-2010, 05:11 PM #5Just me
- Nov 2006
- Broken Arrow, OK
I agree with whats been said above, fronts would be no issue. I run 11s in the rear and can't imagine fitting 12s. My 11s didn't clear by much.
04-19-2010, 05:17 PM #6Senior Member
- Oct 2008
- Coral Springs, Fl
i got 11.5s on a 50mm offset and they are a tight fit
12s would fit on the right offset but they will probablt stick out the wheel wells a gppd amount. You will also most likely have to ogrind off your bumpstops do lots of hammering and roll your lips
tired will most likely cost a fortune 18s cost more than enoughLast edited by tatertot91; 04-19-2010 at 05:19 PM.
04-19-2010, 05:27 PM #7Senior Member
- Feb 2010
- Greenwood, IN
Light Pewter Metallic- 2001 Camaro SS
these would work http://www.oewheelsllc.com/Wheels-fo...02413-3-1.html. You can call them and they probably have them in different finishes
04-19-2010, 05:34 PM #8
04-19-2010, 05:52 PM #9Senior Member
- Feb 2010
- Greenwood, IN
thanks for pointing that out to the OP. I personally would go with something like this http://www.oewheelsllc.com/Wheels-fo...02392-3-1.html. Except I wouldn't get the rivets and I would get the front in 18x8.5
04-19-2010, 05:55 PM #10
04-19-2010, 05:57 PM #11
04-19-2010, 06:08 PM #12
04-19-2010, 09:14 PM #13Member
- Nov 2006
- Sunniest city on Earth
- 2011 Silverado CC 4x4 6.2
I like the way it looks on some rims, not so much on others. Huge fan of the adaptability of three-piece wheels, but I have to agree that it would suck to clean them.
04-20-2010, 07:31 AM #14Knight Rider
- Jul 2009
- Charleston, SC
Thanks. I'll have to look into those.
Adapter?
Those look pretty good too. Hmmmm. I'll just have to keep looking around and see what I can find.
And someone asked about the offset of the ones I posted: 40mm offset up front and +59mm offset in the rear. I'm assuming that doesnt really help me. Can anyone give me any general guidelines for what will fit and what the limits are of what will fit on an f-body?
04-21-2010, 01:48 AM #15Senior Member
- Oct 2008
- Coral Springs, Fl
Adapter meaning it probably has too big an offset so it'll probably rub. You'd need a spacer to pull the wheel out more. Also wouldn't recommend spacers, if you really have to i would recommend longer hardened wheel studs.
Not sure what exact one will fit, it all depends on how wide the rim is. How wide do you wanna go, and how much are you willing to spend? (wheels, and tires)
04-21-2010, 10:13 PM #16Knight Rider
- Jul 2009
- Charleston, SC
I want to go wide enough to give it badass looking stance, but I dont want to go too wide becaues I'd like to do a little road course racing and some auto-x with it. And I dont have that much money so I was hoping around like $800 max for rims. I know that kind of limits me but I dont have too much money to work with right now.
04-21-2010, 11:59 PM #17
04-22-2010, 04:20 AM #18Senior Member
- Oct 2008
- Coral Springs, Fl
If you don't have a lot of money get 17s, tires are much cheaper
04-22-2010, 07:29 AM #19Knight Rider
- Jul 2009
- Charleston, SC
Well, I guess 10" in the back and 9" up front? Would that look decent? What's the biggest that I can go in the back without having to do any modifications to the spacing and all?
It'll only be a DD for a little while and then it will be just a weekend car so tires will last a good while.
04-22-2010, 10:07 AM #20
Question: OEM wheel fitment.
By Dsmdave in forum GTOReplies: 12Last Post: 07-02-2012, 08:33 PM -
99 chevy wheel fitment
By joejenkinsglass in forum GM TrucksReplies: 8Last Post: 01-06-2010, 06:38 PM -
wheel fitment
By damianj03 in forum Wheels and TiresReplies: 1Last Post: 08-05-2009, 07:15 PM -
wheel fitment
By o2 z28 in forum Wheels and TiresReplies: 0Last Post: 06-24-2007, 03:52 PM -
Wheel fitment Q.
By graveyardman in forum Wheels and TiresReplies: 1Last Post: 12-09-2005, 04:18 PM
