Thread: Strano/koni
04-18-2010, 08:41 AM #1Junior Member
- Jan 2009
- los angeles
blue- 2000 camaro
Strano/koni
Ls1, what is tge most common setting on the koni 4/4 rear and fronts, and I'm sitting on the Strano springs.Just in stalled them a couple days ago and wanted to see which setting y'all been using. And why when I have extra weight in the car, the ride is much smoother even over bumps.
04-23-2010, 07:36 AM #2
half way for the fronts and 1/4 turn up from full soft for the rear
04-23-2010, 07:41 AM #3
I'm surprised no one has responded to this yet!
Okay, I have 500# front springs and 150# rears, I like my ride to be firm so my fronts are 4 sweeps from full stiff, rears are 1/2 turn.
I have the DA shocks but basically it should be close to the same.
Now...you will need to play with your front shocks first, set it to full soft, see how many sweeps you have to go from softest to firmest, and put it somewhere in the middle, which is what I did, I just added another sweep to firmer and I haven't touched it since.
More weight in the car means your shocks are now having to dampen more weight, so what might have been stiff is now wallowy, does that make sense?
EDIT:
okay two replies so far hahaha!
04-25-2010, 07:00 PM #4Junior Member
- Jan 2009
- los angeles
blue- 2000 camaro
Thanks for the replies. Just thought i get some opinions before i play with the adjustments. Both shocks are turned halfway for now, i plan to adjust this week. and yes that makes sense.:
Strano springs and Koni shocks
By devildogws6 in forum Suspension and HandlingReplies: 29Last Post: 03-17-2010, 05:39 PM -
Anyone have Strano Bilsteins / vs Koni
By mrsracing in forum Suspension and HandlingReplies: 1Last Post: 06-27-2009, 07:02 AM -
Koni/Strano: what a difference!
By sfletch2000 in forum Suspension and HandlingReplies: 31Last Post: 04-29-2008, 01:53 AM -
Wanted: ***Koni SA's & Possibly some Strano Springs***
By TooFastT/A in forum Parts Wanted / TradeReplies: 6Last Post: 04-23-2008, 09:26 AM -
Strano Springs & Koni SA's are on!
By Tnhillbilly in forum Suspension and HandlingReplies: 14Last Post: 08-09-2007, 07:41 AM
