Results 1 to 10 of 10
Thread: Anybody installed one of these?
02-26-2006, 03:38 PM #1CamaroKillZ28Guest
has anyone here installed a Pro 5.0 shifter? I have one on the way, should be here around the middle of the week or so...any thing i need to look out for? or is it pretty much straight forward?
03-01-2006, 07:57 PM #2
It is pretty straightforward, but do keep in mind that you need a set of feeler gauges to get it adjusted properly.
03-05-2006, 04:24 PM #3
The hardest part is pulling the console out. You have to stand the e-brake handle straight up in the air to remove the console. At least you do in a TA. Also I think you have to cut a little bit of the lower shifter boot to get it to fit over the new shifter base.
When I did mine I just followed the right up on install U's website. If you do what they tell you too you'll be done in no time. They also have pretty pictures.Last edited by smokin_ls1; 03-05-2006 at 04:40 PM.
03-05-2006, 05:15 PM #4
03-05-2006, 05:49 PM #5
Pulling it out?? I think its 5 times worse trying to get that bitch back in. Drives me insane.
03-05-2006, 06:20 PM #6
I had no problems putting mine back in. It wasn't hard to take apart. Getting the e-brake in the right position is a little tricky though. I put some teflon tape on the bolts to keep them from backing out.
03-06-2006, 05:02 AM #7Member
- metro Detroit area
The teflon tape will make them loose totque.They may go in easier, though. You should have used a thread locker( Loctite)
03-06-2006, 03:49 PM #8
Are you talking about the ones that go in the trans or the ones that hold the tower together?
03-13-2006, 08:52 PM #9
You guys had to take the console out? Was never a problem for me?
03-15-2006, 06:11 AM #10Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
its pretty simple.
www.installuniveristy.com is your friend
PHB installed
By Formula Dave in forum Suspension and HandlingReplies: 18Last Post: 01-21-2008, 09:11 AM -
just installed B&M..!?
By NIKDSC5 in forum CorvetteReplies: 6Last Post: 12-31-2007, 02:31 PM -
Need a Cam installed in MD
By INeedLS1 in forum Eastern MembersReplies: 6Last Post: 05-16-2007, 03:21 PM -
SLP lid installed
By jag42420 in forum External EngineReplies: 4Last Post: 09-12-2006, 09:32 PM -
Got my cam installed
By BlackBeastLS1 in forum Internal EngineReplies: 18Last Post: 08-23-2006, 11:02 AM
