    TerribleTed TerribleTed's Avatar
    California-Sacramento-Roseville
    2000 Chevy Camaro Z28
    So my vavle leak is fixed, now what
    The cross roads..
    Initially my fubar downshift resulted in 1 bent push rod, then later I found a single intake valve bent. (Spinning a valve in a drill is a great way of seeing if there are any imperfections) Once I replaced the single valve with a new one, I poured water into the intake runners of the head and walah...no more leaks,,,
    So now the cross roads.
    Remove the other cylinder head that is still on the car, then replace all 16springs to better stronger ones, etc...or just replace the single valve that is bent (which is done now) and install the single cyl head I removed.
    My car has 200k on it,,,but to be honest,,,all my valve seats and runners and the general look of my piston tops, makes me think the motor is still in very great shape. (i have not done a wet comp check sad to say)...
    So what after market valve springs would be great to install? Links or data would be great....
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by TerribleTed View Post
    The cross roads..
    I'm amazed the valve guide was still good after a bend valve..
    Well all the valve seats seemed fine,,no dents,,,gashes,,,and the guides,,,well using only hand pressure and touch senses-i found none of the guides to differ in how much play they had,which was like hardly any...
    So a single intake valve,,,very very slightly bent,,,,caused a compression of 25 lbs,,
    I would not see why the guides would get stressed if the valve itself was bent on the end portion and not the stem portion,,,but thats just me,,,
    So back to my original question,,,what valve springs would be a direct bolt on that offered more spiring power,,,,IE,,,longer life,,,,,
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    If you wanted some slightly stronger springs, the ls-6 springs. Can be had for under $150 brand new if you look on craigslist. I think they are good up to .525 lift.
    kool,,,i shall check into them,,,if s direct fit with all my other stocker stuff,,then in they shall go this week end,,,
    Bay Area
    my highbeams
    yep fit in just like the stockers
  1. Ory Leak........but Fixed It
    By SMWS6TA in forum External Engine
    Last Post: 11-07-2010, 03:57 AM
  2. PIX are fixed
    By Boomer Sooner in forum Camaro / SS
    Last Post: 07-28-2008, 02:14 PM
  3. My car is fixed
    By joker in forum Firebird / WS6
    Last Post: 04-22-2008, 02:21 PM
  4. ttop leak, hatch leak, and window motor problems
    By ATCharming in forum General Help
    Last Post: 07-23-2007, 02:30 AM
  5. Fixed Header Leak..
    By LS-One in forum External Engine
    Last Post: 07-13-2007, 11:44 AM
