    Senior Member Lunatikgixxer's Avatar
    Mar 2010
    St Pete, FL
    Bat mobile black
    2000 Trans am WS6 M6
    Can someone explain to me
    What this is exactly, obviously an o2 but what does it do?
    edit: Innovate Motorsports LC-1 Wideband Controller Cable & O2 Sensor
    [3769] $169.99
    Ive tried searching it on this site or google to see anymore info on these but couldnt find much help, thanks guys.
    Last edited by Cutlass; 04-15-2010 at 06:04 PM. Reason: removed non-sponsor direct link
    NeW YoRk
    2001 ws6
    no idea, subscribing to learn something
    Member importhater81's Avatar
    Oct 2009
    chicagoland,Il
    02 ss camaro
    It's a upgraded o2 sensor for your car.Wideband o2's measure and dial in A/F ratio more precise than the standard o2's do.They actually tell the PCM how much lean or rich the A/F ratio is,as opposed to regular o2's that just signal lean or rich.
    Mar 2010
    St Pete, FL
    Bat mobile black
    would they be worth buying? I mean are they that big of a difference?
    Oct 2009
    chicagoland,Il
    02 ss camaro
    Quote Originally Posted by Lunatikgixxer View Post
    Don't know if they're worth buying,Ive never used them.
    What are you trying to do with your car?What mods? I'm pretty sure that a good tune would probably be better than the wideband o2's
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Please don't post direct links to non-sponsor websites.
    Mar 2010
    St Pete, FL
    Bat mobile black
    o sorry i didnt know we couldnt, maybe if i did some reading id know, lol. Im just trying to have a nice clean, fast street car, dont really care much about the strip. I was just curious if they would be worth buying over the regular o2s. And yes i need a tune.
    they're a tuning tool more than anything else. If you plan on heads/cam or something like that I would recommend running one just so you always know what your AFR is. Is it required to have one? Not really unless you plan on doing your own tuning.
    A wideband is just much more accurate at giving you AFR data over a larger range than a narrowband. A narrowband is meant to work right around stoich and operates on 0-1v where as a wideband operates on 0-5v.
    Mar 2010
    St Pete, FL
    Bat mobile black
    ok i understand now, thanks man
  1. Can someone explain what's going on here??
    Last Post: 05-19-2010, 06:34 PM
  2. can someone please explain
    By 5second in forum Firebird / WS6
    Last Post: 10-17-2008, 05:06 AM
  3. Can someone please explain...
    By CaptainCaveMan in forum Political / Debate Forum
    Last Post: 10-07-2008, 03:56 PM
  4. Can someone explain this to me?
    By FSANE in forum Almost Anything Goes
    Last Post: 12-12-2007, 07:06 PM
  5. Cant Explain This One!!
    By ftast1z06 in forum General Help
    Last Post: 08-28-2005, 08:16 AM
