    Aug 2009
    south carolina
    whats the best sleeper camshaft
    whats the best cam u can buy if you want to have a sleeper that also will work good on the nitrous and have good driveablity i will be using the prc heads from texas speed more than likely and if yall can give me some info on those head will be good to
    Jun 2009
    coon rapids, MN
    2000TA
    a cheater3 cam.at another forum a guy was using stock exhaust and ran 12.2 with this cam. With NOS he ran 11.6.
    Senior Member 00z28bubba's Avatar
    las vegas, nv
    2000 Z28
    just about anything with a high lsa. check specs on the cams and the lsa listed will give you an idea of how mellow they are at idle. 114 and higher will give a smoother idle the higher the number is. the lower will give more of a chop at idle like old school muscle cars. as far as if it works with nitrous i dont know if certain cams like blower style cams work better with nitrous over strong n/a cams.
    Member JRENIGAR's Avatar
    Oct 2009
    arkansas
    99 camaro
    Normally a higher lsa works better with nitrous or blower. It gives broader torque range.
    Miami, FL
    2004 GTO
    No. It is the overlap which determines the lope of the camshaft and hence the stealth or noise factor.
    Factory LS1 camshaft has -26 degrees overlap.
    LS6 camshaft has -23 GT2-3 about the same.
    All are about 117-8 LSA
    But you can also have a 112 degree with -12 degrees overlap and ideal smoothly.
    Close to 0 degrees, more chop.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    http://www.thunderracing.com/catalog...vid=3&pcid=226
    pretty sure you could order the cam without the heads
  1. So Would This Be Called A Sleeper?
    By CJREX in forum Almost Anything Goes
    Last Post: 11-29-2012, 07:23 AM
  2. CAM POLL!!! Whats the Camshaft you went with??
    By matt evans in forum Internal Engine
    Last Post: 02-08-2012, 03:13 PM
  3. sleeper set up - what do we all think???
    By 1BADDLS1 in forum Internal Engine
    Last Post: 04-24-2007, 04:24 AM
