Thread: how do i post pictures?
02-26-2006, 09:19 AM #1unicyclemidget11Guest
i need help with my wiring for a cut out and i want to post pictures. How do i do this?
thanks
02-26-2006, 09:37 AM #2Senior Member
- Jul 2005
- Jacksonville, FL
Maybe we can help without pics - I've installed the QTP a couple times.
02-27-2006, 07:16 AM #3unicyclemidget11Guest
alright. i bought a cut out from street pro. From the cut out there is two wires, a black one and a white one. From the switch there is four wires. Two short and two long wires. Each set consists of a black and red wire. Now which wires hook up to where? I'm assuming the longer wires will connect to the cut out but what color to what color? And also, where can I hook up the (i'm assuming the shorter set) wires from the switch for power to use the thing? I think it said I need a 10 amp source.Where can i hook up for this?
There's a diagram on the street pro site. I can't post the link because i haven't posted enough.
i only have one cut out to hook up. Can you help me?
thanks
02-27-2006, 08:50 AM #4Senior Member
- Jul 2005
- Jacksonville, FL
Is this the wiring diagram you're looking at? www.streetpro.us/SSWireDiagram.html
02-27-2006, 12:16 PM #5unicyclemidget11Guest
yeah. im assuming the short red goes to a 10 amp power source. The short black is grounded somewhere. The long red hooks up with the white wire from the cut out and the black wire from the switch hooks up to the black wire from the cut out. Correct? Where can i hook up for the 10 amps? Where can i ground it?
thanks
02-27-2006, 12:49 PM #6Senior Member
- Jul 2005
- Jacksonville, FL
Wish that diagram gave the colors of the wires coming off the cutout motor - but it's a momentary switch and shouldn't make any difference - says you can't wire it wrong. I believe you're correct on the wires to the motor. Depending on where you mount your switch you need power (red wire with the inline fuse) from a "switched" power source. I extended it and ran it under the carpet to the radio fuse - you can also use the pink wire behind the TCS switch (think it has power to the connector even if you car doesn't have it). For ground I extended the black wire and tapped into the black wire off the cig lighter. Since both switch wires are short you'll probably have to use butt splices and some wire to extend them. Hope this helps...if you make a mistake it'll just blow the inline fuse from the switch.
02-27-2006, 01:25 PM #7unicyclemidget11Guest
so can i tap into a power source that is more than 10amps but it can be less than 10amps correct? what do you mean to the radio fuse? you mean the wire coming out of that fuse?
02-27-2006, 02:07 PM #8Senior Member
- Jul 2005
- Jacksonville, FL
Read there somewhere the switch power has an inline 5 AMP fuse, so it if draws more than that it'll blow. 15 AMP radio fuse is fine for power. I just stripped the wire back, removed fuse, stuck the wire in one side and used the fuse to hold it in.
02-28-2006, 06:32 AM #9unicyclemidget11Guest
alright, thanks. ill tell you how it goes. doing it friday.
03-01-2006, 06:26 AM #10
i put a qtp cutout on my car, (2000 ws6). i dont know what kind of car your putting this on but if its an fbody then you can do it like this... i used the positive wire(pink) from the cig lighter on the center console for my power source and the negative(black) wire for the ground. The cig lighter still works fine and pushes enough power for the cuout motor. I dont have traction control so i was able to mount the switch on the driver's side of the center console about an inch above the carpet.
03-01-2006, 06:50 AM #11unicyclemidget11Guest
how many amps are going to the cig lighter? it says i need a 10 amp source. its an 02 firehawk with t/c.
03-02-2006, 08:44 AM #12
ok i looked at the old instructions and it didnt say anything about amps. it just said connect to a 12volt power source. and the positive wire(pink) was for the traction control - not to the cig lighter, but i did use the negative(black) wire from the cig lighter for a ground. i dont have tcs on my car but the wire was there just not connected to anything that i could see. the qtp switch had a fuse holder on the hot wire which i connected to the t/c wire. does your switch have a fuse/?.
post your other car pictures
By lsmaxxed in forum Firebird / WS6Replies: 32Last Post: 06-28-2011, 04:18 AM -
By jackclark32 in forum Member's RidesReplies: 2Last Post: 05-03-2010, 07:06 AM -
How to Post Pictures on ls1.com!
By JoshieDoom in forum Request and FeedbackReplies: 5Last Post: 05-18-2009, 06:07 PM -
Question: how do i post pictures
By SSMOKEshow in forum Camaro / SSReplies: 2Last Post: 03-26-2009, 03:52 PM -
trying to post pictures
By 99transamC/FIA in forum Almost Anything GoesReplies: 11Last Post: 06-19-2008, 05:40 AM
