    Just a farmboy V8MUSCLE's Avatar
    Montpelier, VA
    2000 Pontiac Trans Am
    mity vacing a clutch
    does this get all the old fluid out, or just any air/moisture out.
    im interested in bleeding my clutch 140k miles original fluid but want to try to get all the old out and new in.
    phoenix
    04 2500 4x4 crew cab
    i dont think so, it would pull the seals before you got much fluid out. you could cut a hole in the tranny tunnel, and open the bleeder screw and run fluid through it to flush it. or jack it up and maybe be able to reach the screw. maybe.
    Try roasting your crow. It'll be easier to get down.
    I like grilling mine with a nice brown sugar based rub
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Quote Originally Posted by az gt eater View Post
    Correct. You can reach the bleeder without cutting the tunnel. Two man job though.
    MityVac is amazing for bleeding the clutch. Sticky up top on the MityVac bleeding procedure.
    phoenix
    two man? what i did is i put the mity vac in the master, applied suction and then went inside and pumped the clutch a bunch of times. it pulled air bubbles out, and like 6 strokes i was done. idk y i cut that hole in the tunnel.
    Florida
    1999 TA WS.6
    Two man without the MityVac.
    phoenix
    gotcha
  1. How to bleed a clutch with a Mity Vac
    By Hi-Po in forum Manual Transmission
    Last Post: 06-24-2014, 05:20 PM
  2. Replies: 21
    Last Post: 12-13-2007, 07:41 PM
  3. clutch locks up 1st gear in traffic while riding clutch
    By Trixter in forum Manual Transmission
    Last Post: 04-22-2007, 09:01 AM
  4. Mity vac hook up?
    By flashit in forum Manual Transmission
    Last Post: 10-17-2006, 12:27 PM
  5. z06 clutch for sale, pressure plate clutch disk and flywheel
    By themack56 in forum Parts For Sale / Trade
    Last Post: 07-06-2006, 07:15 PM
