04-08-2010, 05:27 PM #1
and i was excited for warm weather =/
drove my 96 lt1 today and after 15mins of driving i got home and heard the radiator making funny noises. came back out and all the coolant had leaked. now my car over heats and the thermostat in the dash was over the red bars in like 10 mins of driving.. so i go buy some coolant (dex-cool 50/50 i believe) fill the reservoir tank but it still overheats on the way home. get home and fill the radiator turn the car on without closing it. as the car started to heat up coolant overflowed out of the radiator.. is it clogged? maybe the valves or the radiator its self.. or did it do that cus the radiator cap wasnt on.. any help will be greatly appreciated..
04-08-2010, 05:38 PM #211 years of bangin gears
- Jan 2009
- North Jersey
Have you checked to see if your radiator split? I think coolant will overflow if the cap isn't on. I am getting many different symptoms reading the first post. Have you flushed the cooling system at all? Have you replaced the radiator cap at all?
04-08-2010, 07:08 PM #3Member
- Nov 2009
- Norfolk, Nebraska
- 2002 Camaro Z28
Your first couple sentences make it sound like the radiator went as cammed goat mentioned. Really need to find out where the leak is before driving it much more.
Junkyard bought and "refurbished" 2002 Camaro Z28 - Pacetter Race LT's, TS&P ORY, Frost tune, Magnaflow, Ported TB, SLP Lid, Circle D 3000, 3.73's, SFC's.
2009 Silverado Z71 - Magnaflow
2008 Impala LTZ - Wife didn't want the V8 SS!
04-10-2010, 04:06 PM #4
Sounds more like thermostat or fans not kicking in. Let it cool down, fill the radiator, start it and see if the fans come on when it starts to get hot. If they do, shut it off and replace the thermostat.
04-10-2010, 04:10 PM #5Member
- Jul 2007
- tx
black- 1994 camaro z28 a4
sounds like the efans arent turning on u should check the ground same thing happened to me cause my efans werent making good contact cause i had painted the light bar
Where's the Warm Weather?
By kheflw in forum Firebird / WS6Replies: 19Last Post: 03-01-2010, 02:28 PM -
I am so excited!!!
By blackSS01 in forum Almost Anything GoesReplies: 17Last Post: 02-16-2009, 09:04 PM -
Warm weather T/A owners should be happy..
By Ryans99LS1 in forum Firebird / WS6Replies: 34Last Post: 03-06-2008, 11:16 AM -
warm weather for a day
By 2-bowties&abird in forum Almost Anything GoesReplies: 3Last Post: 02-07-2008, 04:42 AM
