Thread: remove window film?H
04-06-2010, 04:52 PM #1
Howdo you remove film.Do i need a pro. Tommy
04-06-2010, 06:20 PM #2
I've seen it done before but your best bet is a pro- it's very easy to tear up the defrost strips on the back window.
04-06-2010, 07:27 PM #311 years of bangin gears
- Jan 2009
- North Jersey
I agree. Leave it to a professional. It'll be alot cheaper in the end.
04-06-2010, 08:02 PM #4Senior Member
- Oct 2008
- Coral Springs, Fl
not that expensive to have someone else do it, maybe someone will chime in on doing it yourself though
04-06-2010, 08:57 PM #5Junior Member
- Jan 2010
- New Mexico
- 1999 Chevy Camaro z28
I just did mine last week and i soaked the film in 409 and it came off easy and then i used goo gone to take the glue off it was easy
04-07-2010, 06:40 AM #6
Everything I've seen says use ammonia and cover it in plastic- 409 is some strong stuff so it should do the trick. I have to get mine done. Idiot who had it before the guy that I bought it from had tinted the windows himself and they look like crap. Really messed up the factory tint so I have to have it all stripped off and re-done.
04-07-2010, 06:47 AM #7Member
- May 2008
- Michigan
As said above will work or get a black trash bag and put it on the outside of your car. Make sure its a really sunny day. Wait 30 minutes and peel off. Use a razor blade with soapy water to remove glue. If your tints on the back window do the same thing but be very careful with the blade. If you have a light pad of some sort u maybe able to use that.
04-07-2010, 08:28 AM #8
I was replacing passerger side window motor,drill out wrong riv. wound up taking out whole slider,and window sliped when i was geting up and grab it for balance.Its hell geting old.Put several scratches in film.Tommy
04-07-2010, 08:17 PM #9
The best and safest way is to use a steamer.
It should come off with little glue residue.
A friend of mine is a pro tint installer and I've seen him do this a few times.
It works like a charm...
04-08-2010, 11:13 AM #10
Steamer for the win.........
04-08-2010, 11:23 AM #11
I agree. The tint itself just peels right off. I used a Shark portable steam cleaner to get the glue off. Real easy. DO NOT use a razor blade on the passenge windows. Scratched one of mine all to hell and had to replace the glass. As for the back, I had no problems with the rear defroster strips using the methods I described. I wouldn't pay someone else to do it.
04-08-2010, 12:01 PM #12Member
- May 2008
- Michigan
did you use a dull blade with no water? If you use a sharp blade and water you shouldn't have issues with scratching. worked like a charm. Never thought about a steamer but next time ill use that.
Question: Whats the best way to remove window tint?
By wickedbeast in forum Appearance SectionReplies: 5Last Post: 05-11-2011, 07:59 AM -
Small piece of window tint film
By pajeff02 in forum Parts Wanted / TradeReplies: 7Last Post: 07-08-2010, 01:35 PM -
Name that Porn Film for Hi Po
By Sarge in forum Almost Anything GoesReplies: 73Last Post: 07-26-2008, 12:55 PM -
how to remove window tint?
By william SS in forum Appearance SectionReplies: 3Last Post: 10-12-2007, 09:41 AM
