Results 1 to 1 of 1
Thread: 96 opti vac line routing?
04-06-2010, 01:54 PM #1
96 lt1
There are 2 connections on the opti drivers side, one top, one bottom, for vac hoses...and i have 2 hoses, one with blue/white valves, and one without. i found the pic below so i know the one with the blue/white valves connects to the intake manifold by pcv, and thus the other hose connects to the intake tube... but which ones top/bottom on the opti itself?
ie. intake manifold to top or intake manifold to bottom, and intake tube to top or intake tube to bottom.
ps. there is a vac split on the intake manifold... where does the other line go? its not pictured on shbox.com, and its too tight back there to follow if with your fingers unless you remove the tcs box and mounts...which im not doing. its hard plastic and goes stright back then maybe down towards the back of the motor.Last edited by grandkodiak; 04-06-2010 at 05:51 PM.
02 sensor extention routing?
By 99formulals1 in forum External EngineReplies: 10Last Post: 03-14-2010, 06:09 PM -
Clutch master hose routing?
By Cutlass in forum Manual TransmissionReplies: 3Last Post: 02-15-2010, 03:37 PM -
98' Z28 coolant routing
By LS1 C10 in forum General HelpReplies: 1Last Post: 07-16-2008, 08:52 AM -
help! pcv tubes routing
By astyles in forum External EngineReplies: 2Last Post: 09-08-2007, 02:45 PM -
C5 Exhaust routing...
By Jon02EB in forum CorvetteReplies: 6Last Post: 06-09-2007, 04:34 PM
