Results 1 to 2 of 2
Thread: Fuel pump replacement
04-06-2010, 04:32 AM #1
Just bought a wal 255 fuel pump... I was wondering, what else should I replace that would be convinient to do so when the garage does it? I know the rear has to be dropped a good amount and the tank slide back and out. Anything such as relays, connectors, harnesses etc that will be assessible that could be replaced as a prevent while its all open and out?
04-06-2010, 01:45 PM #2
Dont replace any harness or connectors unless they need it. It is a good time to inspect all of these items though for wear and tear. If you want to install a Racetronix harness (for improved fuel pump performance), now would be the time. Make sure everything else related to the pick up unit inside the tank is in good shape. Maybe a new pickup filter, gaskets, seals, etc.
Fuel pump Replacement????
By Speeddemon24_7 in forum External EngineReplies: 12Last Post: 02-14-2013, 03:13 AM -
By JayTA98 in forum General HelpReplies: 7Last Post: 07-04-2012, 10:12 AM -
Fuel Pump Replacement
By excrider121 in forum External EngineReplies: 11Last Post: 10-13-2010, 10:56 PM -
By LS1PowerBroker in forum External EngineReplies: 2Last Post: 09-05-2006, 07:50 PM -
By redz284u in forum General HelpReplies: 20Last Post: 10-07-2005, 03:08 AM
