Thread: That little strap on PCV.....
04-05-2010, 07:49 PM #1Senior Member
- Jan 2010
- texas
silver- 2000 formula
got my 3 book factory manual set in..............thanks ebay..........was lookin through it......found the PCV section.........it calls that strap from the PCV to the top nut on the coolant tube..........a heat transfer strap......WTF? ......and here all the while i thought it was some sort of ground strap............the things you learn
04-05-2010, 10:13 PM #2
that's a new one on me too.....it's been a long time since that's been on my car. I always figured it was a ground strap to keep static from building up from the gases running through the pcv tube and possibly lighting something off in there. I forget even where that went to but I though it grounded to the fuel rail.
04-06-2010, 03:12 PM #3
^^^ It is on the rail, your right. I think its made of aluminum so that explains the heat transfer part. Not sure it was necessary though.
04-06-2010, 04:16 PM #4Senior Member
- Jan 2010
- texas
supposed to keep condensation down in the valve.........go figure
04-06-2010, 04:36 PM #5
In really cold weather, the moisture from the engine being sucked through the PCV in a venturi type of effect could freeze, that's what the strap is for.
Anyone ever devise a torque strap?
By Firebirdjones in forum External EngineReplies: 6Last Post: 09-25-2007, 05:39 PM -
GROUND STRAP?? For Pollen?
By LETHALxLS1 in forum Showcar and DetailingReplies: 19Last Post: 05-24-2007, 06:44 PM -
Gates Rubber Grounding Strap
By erikzola in forum General HelpReplies: 0Last Post: 04-15-2007, 02:42 PM -
Ever want to strap jet engines to your legs?
By grandkodiak in forum Almost Anything GoesReplies: 9Last Post: 04-26-2006, 06:25 PM
