Results 1 to 20 of 20
Thread: egr delete
04-04-2010, 06:40 PM #1
egr delete
i have a 2000 SS camaro and was just wondering if it was worth geting the egr delete. or does it just make the engine bay look a little cleaner looking? is there any gain out of this mod?
04-04-2010, 07:31 PM #22002 Arctic White T/A
- Sep 2009
- Houston , Texas
Metallic Pewter- 2002 SLP Firehawk
hmm do you even have egr? i whent through this lol i dnt think after 99 or 98 theres egr but im no expert but i dnt think there is any gains or losses, but its worth it it looks very clean in there and its problably a 15 to 30 min mod. if its even called a mod
04-04-2010, 07:35 PM #3
2000 and below had EGR, the only gain you will see from it is a cleaner engine bay
04-04-2010, 07:44 PM #42002 Arctic White T/A
- Sep 2009
- Houston , Texas
there you go, i wasnt sure if they did or didnt but i knew there was no gain nor loss but cleaner engine bay belive me once u do that u have acces to lots of things and all that hose wont be in your way.
04-04-2010, 08:11 PM #5
04-04-2010, 08:32 PM #6
and a tune is recommended afterwards to zero the EGR timing table.
04-08-2010, 08:16 AM #7
ok so if i get the egr delet and get headers i can get the 01 02 style headers correct? insted of geting the ones for a 2000 that has the egr fitting in the passenger header... right? will they still fit?
04-08-2010, 08:44 AM #8
yeah....they'll still fit.
04-08-2010, 11:09 AM #9
if yor doing a EGR delete may as well add a WS6 intake. Pick them up cheap usually off a newer car that someone bought a Fast set up for.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
04-08-2010, 01:53 PM #10
04-09-2010, 08:19 AM #11
04-11-2010, 12:10 PM #12
04-11-2010, 04:44 PM #13
04-11-2010, 04:47 PM #14
2 different systems. The air system connects to both exhaust manifolds and has check valves. Lines run from those to a pump that's behind the drivers side headlight.
The EGR connects to the passenger manifold only and runs through the egr valve and into the top of the intake.
04-12-2010, 05:23 AM #15
actually you might get a little more flow out of your intake when you delete the egr.because you dont have that big tube sticking down right behind the throttle body butterfly.im sure that egr tube is resricting flow.remove it and your intake will flow better.dont know if you will notice it,but it will flow better.
04-12-2010, 09:06 AM #16
04-13-2010, 09:05 PM #17
04-18-2010, 04:03 PM #18
04-18-2010, 07:09 PM #19
04-20-2010, 12:51 PM #20
Question: MAF Delete??????
By 98SSLS1OWNER in forum Computer & TuningReplies: 37Last Post: 12-06-2010, 03:03 PM -
MAF delete?
By tomz28 in forum General HelpReplies: 20Last Post: 06-30-2009, 02:36 PM -
EGR & AIR delete
By 96t/a in forum LT1Replies: 10Last Post: 04-10-2008, 04:33 PM -
Delete This
By ss~zoso~ss in forum Political / Debate ForumReplies: 0Last Post: 02-06-2008, 12:53 PM
LS6 intake, not WS6 intake
