Results 1 to 20 of 22
04-02-2010, 06:18 PM #1Senior Member
- May 2009
- Toronto
SOM- 2002 SS
SLP lid fits like crap. Questions ....
Well I just finished up a lid install with SLP bellow. Was fairly simple except 1 thing. The resonance chambered piece of plastic on the stock airbox fits to the stick lid on one end and on the other it has NO rubber slip on tubing and fits directly on the maf. Right now I gave the SLP lid slid directly on the maf is this correct? I don't know what year lid it's off .. I'll check when I'm not typing on my iPhone while I drive lol. My z is an 01.
Other than that I can't see how the intake van flex with engine movement but soon I'll have poly mounts with the lt install so that shud help.
Any thoughts ?
04-02-2010, 06:26 PM #2
Lol guy. That resonance chamber doesn't go back on. If you have a smooth bellow or the accordian (stock) bellow it hooks up like so: lid, bellow, maf. It should be a perfect fit, after that hopefully it clears your hood
04-02-2010, 06:52 PM #3
That's backwards, if you are starting at the lid,,,the MAF will slide into the lid,,,,THEN the bellow goes on, which attaches to the throttle body.
I have the same setup. It went together fine for me, but I've heard others had problems. It's been mentioned that a heat gun was necessary in some instances,,,,I guess to heat the lid to install the MAF in there.
On your other concern, I have stock motor mounts and have never had an issues with engine flex affecting the lid. But I know what you mean, since it all fits snug it would seem that engine movement could crack the lid. Mines been on there for 3 years or so now without a problem.
I do however remove the assembly before pulling the transmission, or removing the cross member for any reason and letting the back of the engine droop.
04-02-2010, 07:10 PM #4Senior Member
- May 2009
- Toronto
SOM- 2002 SS
Firebird got it right that's exactly how it's on right now. Lid, maf, bellow to tb. My original concern was the lid to maf. I found it surprising that a hard plastic lid had to pretty much be press fit onto an aluminum maf. The fit was extremely tight.
On the bright side since I put it on at my parents house I had tons of stuff in the garage to try and test fit into the air hose on the lid. Eventually I got this wired looking piece of plastic to fit in there so clean it looks oem. I figured since I'm deleting the egr and air with the lt install I may as well try to figure out how to plug it now. I'll get a pic of the piece I'm sure it can help someone who wants yo do it . Also the lid was in gr8 shape too so it looks good.
Anyone think they noticed a difference with a lid ?
04-02-2010, 07:19 PM #5
I used a hairdryer on the lid to make the fitment on the maf easier
And when I did my lid when I was stock I heard a difference (whoosh) I thought it was the coolest thing
04-02-2010, 07:25 PM #6
04-02-2010, 08:21 PM #7Senior Member
- May 2009
- Toronto
SOM- 2002 SS
I didnt really try to notice too hard Ihad a car full of stuff and the temps did drop big time from when I had last driven it. I'll give her a good thrashing soon enough to see if I can notice any difference in sound or performance.
04-02-2010, 09:11 PM #8
04-02-2010, 09:18 PM #9
04-03-2010, 12:34 AM #10
04-03-2010, 04:23 AM #11Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
It's been documented that lid fitment issues can usually be traced to people using the smooth bellow. In most cases the smooth bellow needs to be trimmed for the lid to properly seat on the airbox.
Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
04-03-2010, 07:06 AM #12Senior Member
- May 2009
- Toronto
SOM- 2002 SS
Another EXCELLENT point. When I first tried o get the maf on it wasn't on far enough. When i test fit the setup it was too far forward even with the bellow all the way on the throttle body and i couldnt get the airbox to fit on properly.
I had a rubber hammer and tried to smack the maf onto the lid as far as it would go (I'm an idiot here cuz when i first test fit the maf i pushed it on and could have helped it slip on easier with some lube etc and i couldn't even get the thing off again - hence the mallet)
When I did get the lid on as far as it would go on the maf only then did the airbox lid look like it fit snug and the clips worked like stock. I may end up trimming the bellow a few mm.
04-03-2010, 08:53 AM #13
04-03-2010, 08:57 AM #14
04-03-2010, 12:52 PM #15Senior Member
- May 2009
- Toronto
SOM- 2002 SS
Yeah I didn't like the idea of it too but I couldnt get the dam thing back out without putting wierd stress on the lid so i decided to just leave it in and bang it the rest of the way. More than likely The extra little corrosion on the aluminum ends on the maf didnt help and was probably why the fit was so dam tight.
took a quick pic with the iphone when i finished. Doesn't look bad. I sort of wished I waited till I got home to do it in my garage but I got impatient while i was at my parents. What if someone pulls up next to me on the way home is all I could think of lol.
04-03-2010, 03:13 PM #16Firebird Encyclopedia
- Oct 2006
After dealing with this issue on a couple friends cars I vowed never to waste the cash for a smooth bellow as the HP gain and appearence do not warrant the cost or hassle of assembly. I consider it the same as an aftermarket MAF, Not worth it unless your looking for that last 2-3 HP. JMO
04-03-2010, 08:19 PM #17
04-03-2010, 09:59 PM #18Senior Member
- May 2009
- Toronto
SOM- 2002 SS
04-03-2010, 10:01 PM #19Senior Member
- May 2009
- Toronto
SOM- 2002 SS
Yeah I'm probably going to install the stock assembly back on soon. The bellow is a 0 gain. The Lid I'm still skeptical of a 1 hp gain tbh. I wish i could dyno it for results there is one close to me but I'm not dropping that kind of coin just for lid results.
Anyone want to chip in for a back to back Dyno comparison?? I can make a vid and take tons of excellent pics lol ! I should setup a paypal fund for dyno results
04-04-2010, 05:55 AM #20Firebird Encyclopedia
- Oct 2006
All aftermarket lids provide a gain I have personally seen a few cars drop 2 tenths and gain 2mph at the track. On my own car which I drove for 6 years without a lid I noticed a great SOTP feel and better throttle response.
The car would fight for traction on brisk acceleration as the revs past 3K rpm, which is something it never did before.
Bottom line anything the reduces turbulence and increases air velocity before the MAF is going to provide a performance gain.
Which heads best fits me.
By Cjsmithws6 in forum Internal EngineReplies: 3Last Post: 11-02-2016, 03:02 AM -
It fits!
By 94rt10ohio in forum Firebird / WS6Replies: 19Last Post: 07-14-2008, 07:59 PM -
drag radials what fits
By transampete in forum Wheels and TiresReplies: 2Last Post: 02-27-2008, 04:14 PM -
which aftermarket air box/lid fits the best?
By Semperfiws6 in forum Firebird / WS6Replies: 20Last Post: 04-06-2007, 02:36 PM -
Camaro Bra fits 98-02
By apbtlvr in forum Parts For Sale / TradeReplies: 0Last Post: 11-23-2005, 05:17 AM
