Thread: fuel pump
    1998 z28
    fuel pump
    is fuel pump behind driver rear tire i have 1998 z a zinging noise just started
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    No its more in the center of the car above the rear axle
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    pump is in the tank isnt it ?
    Quote Originally Posted by motley View Post
    are you talking about before the car starts you hear a whine??? cause that is normal... tha tis just the pump priming... if you hear a whine while driving that means your back lash on your rear gears could be off or not shimmed right...
    I believe you're describing the bearings whining. Read the following thread. Might be worth trying and buy you some time on swapping the pump out. If you do swap the pump I highly recommend Racetronix. Where at in Ohio?
    bearing whine thread:
    http://www.ls1.com/forums/showthread...+pump+bearings
    1998 z28
    new at computer not sure who talking to but thanks im from youngstown oh
    Madison, WI
    2001 Silverado Z71
    yes it is
  1. Fuel pump fuel guage issues on my '02 B4C
    By ANDYZ28 in forum Camaro / SS
    Last Post: 12-29-2014, 10:30 AM
  2. Pontiac Fuel Pumps - Do You Have The Right Fuel Pump?
    Last Post: 03-15-2011, 09:20 PM
  3. LS1 all yr fuel injectors, oe fuel rail, pump,more
    By Frost in forum Parts For Sale / Trade
    Last Post: 04-27-2009, 02:26 PM
  4. Replies: 3
    Last Post: 10-02-2006, 06:23 PM
  5. Fuel Pump Pump Problem?????? Help!
    By undertakersT/A in forum General Help
    Last Post: 04-24-2006, 09:55 AM
