    Jun 2006
    Colorado
    blue
    1999 Camaro SS
    Coolant in PS reservoir 1999 SS
    I have a 1999 SS camaro that the PS pump started to whine yesterday. I checked into it today and with some inspection it appears I have some coolant in the PS reservoir and PS fluid in the radiator. I am thinking this could be a bad power steering cooler? I was planning on trying to replace PS cooler, the hose that runs from PS pump to cooler, flush radiator and PS system....thoughts?
    I am in a bit of uncharted territory as I bought the car new back in Nov 98 (4 months delayed as there was a GM strike that year) and with 87k miles other than a cracked H20 pump (was 16 below here in Denver) 4 light bulb replacements, stock cd player motor going out and a sticky clutch pedal in the winter, I have had freakin ZERO problems from this car. By far the best built car I have ever owned!!!!
    Specs
    1999 SS Camaro
    6speed
    dark blue
    all stock except for the SS floormats and the SS badge that replaced the plastic CAMARO badge on the dash...pretty extensive upgrades huh
    Coral Springs, Fl
    Sunset Orange Metalic
    i'd be looking into a new cooler like you said
    Alabama Member bamaz28's Avatar
    Jan 2008
    heart of dixie
    06 Jeep Grand Cherokee.
    02 superchipsZ28 M6(sold)
    welcome to ls1, post your question in the tech section
    welcome to the site... i'll move this thread to the tech section for ya...
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    The PS cooler - 10417037 - is $141 from GM parts. Replace it, then flush the PS fluid and you should be good to go.
  1. oil(?) in coolant reservoir
    By knoll5150 in forum Internal Engine
    Last Post: 06-02-2017, 09:01 PM
  2. Question: Coolant reservoir level goind down but no physical leak?
    By JayTA98 in forum General Help
    Last Post: 01-28-2014, 03:41 PM
  3. Coolant Reservoir size???
    By MK1GTO in forum GTO
    Last Post: 07-01-2009, 06:19 PM
  4. Replies: 23
    Last Post: 06-19-2007, 08:28 AM
  5. ls6 intake coolant plugs or extra front coolant pipe?
    By mikes ss in forum External Engine
    Last Post: 12-03-2005, 05:13 PM
