    Senior Member 98maro's Avatar
    Feb 2010
    north bay california
    00 camaro ss M6 #6695
    Strut tower brace
    Hey guys. I jst put the strut tower brace on my car. I took it for a test drive
    and when I hit after 65/70 starts vibrating. (shakin)
    any idea wat could be the problm? It wasn't like dat b4 I put it on
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    well remember ..you tie the two "posts" together..however it is normal.
    sounds more like an allignment issue... possibly off balance drive shaft...
    Member 4thGenTA's Avatar
    Mar 2009
    farmington
    2002 firebird trans am
    sounds like your tires are unbalanced. Go take it in and balance them.
    Shepherd, Michigan
    98' trans am
    Quote Originally Posted by 98maro View Post
    so the driveshaft just went off balance while the op installed the STB... doesnt sound right
    to the OP. try taking the STB off and see how it drives then..just to see if there is a correlation
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    I agree with taking off and seeing what the results are.
    But if the vibration goes away that doesn't mean you don't have an underlying problem. The tower strut brace might be amplifying it. I would still check tire balance and so on.
    Feb 2010
    B4 didn't have that problm I put the the brace bar yesterday since then had dat problm.
    Tired were balanced last month
    but the car is very low in the front and it might need alignment. U guys think that could fix it?
    NeW YoRk
    2001 ws6
    Since it takes 2 seconds to take the STB off, try taking it off and seeing if it goes away. If its still there you know its not the problem. I cant see the STB causing a problem, is it tightened enough?
    Shepherd, Michigan
    98' trans am
    the stb could just amplify a vibration that already existed
    Feb 2010
    Its tight enogh. So I'll jst take it off and drive it around like dat
    one thing I seen when I changed the oil on the gears the bushings on the sway bar they were all lose. So idk why. I'll check the front ones and see if I c any problms.
    Auto Painter RyanJM's Avatar
    Houston, TX
    I would say check the tires for abnormal looking wear. It could need an alignment and thus amplified it. Also if it's just virating but not pulling to one side you may have lost a balancing weight on a rim which sent it out of balance just slightly and the strut bar amplified it when you hit 65 to 70 would be a speed you would definately notice a balance problem. I had it happen on my car. Allready had the brace but didn't see a pot hole in the rain and off when a weight since it started vibrating right after that I'm guessing that's where I lost it.
    1998 Trans Am 85k miles.
    02 Trailblazer -Sold
    09 Ram 1500 CC - Sold
    09 Cobalt SS/TC - Sold
    Feb 2010
    I'll check the tires
    And if I dnt see nothin visible I'm jst gonna take it sears for the aligment
  1. Strut Tower Brace
    By jmhvenom in forum Suspension and Handling
    Last Post: 08-14-2008, 12:30 PM
  2. Strut Tower Brace
    By Spikito in forum Suspension and Handling
    Last Post: 02-24-2008, 12:43 PM
  3. bmr double strut tower brace or single brace?
    By greatwhiteZ28 in forum Suspension and Handling
    Last Post: 03-30-2007, 11:42 AM
  4. Put On My Umi Strut Tower Brace, Luv How It Looks
    By Y2KJERSEYSS in forum External Engine
    Last Post: 03-26-2006, 06:56 AM
  5. Strut Tower Brace?
    By thelastz28 in forum External Engine
    Last Post: 02-09-2006, 11:02 AM
