Results 1 to 13 of 13
Thread: Do we need run flats?
03-28-2010, 10:00 AM #1Junior Member
- Fort Collins, Colorado
White- 1999 Camaro SS
I have a 2000 Corvette Convertible and I need tires. Do most of you use run flats? They are really high priced. If not which are not too expensive and will last awhile. I can only afford fronts now. My back are about shot too.
I never sold my 99SS so I decided to keep it.
03-28-2010, 11:17 AM #2
You would have to use runflats unless you want to carry a spare tire around in the car somewhere.....
03-29-2010, 07:13 AM #3Junior Member
- May 2007
- Wilmington DE
Pewter- 1998 Corvette
I got rid of the run-flats 4 years ago and went with the Goodyear GS-D3's. The tires are amazing but i carry a plug kit and a 12 volt inflator just in case.
03-29-2010, 11:53 AM #4Junior Member
Plug kit?
Thanks for the information! Where do you get the plug kits? I really don't care to keep buying the run flats. Can hardly afford 2 front tires (not run flat)....
03-29-2010, 01:32 PM #5
Any local parts store would carry a plug kit with the tools needed. They should also sell small style air compressors that run off the cig lighter.
I keep it all in a small plastic tub, about 10 inches by 6 inches. Very easy to store, and even small enough for a vette to carry around without getting in the way.
Ryan has the right idea. You don't want to leave yourself volnerable.
On any road trip, I take it with me even if I have a spare tire. If it keeps me from changing a tire on the side of the road it's paid for itself already. Know what I mean??? I can plug a tire in 30 seconds and be back on my way. It'll save you from anything short of a total blowout or a tire coming apart.Last edited by Firebirdjones; 03-29-2010 at 01:34 PM.
03-29-2010, 01:40 PM #6
Do Vette's come with a full size spare? Even though the fronts are always smaller than the rears?
03-29-2010, 02:50 PM #7
03-30-2010, 12:57 PM #8Member
- Nov 2008
- harrisburg pa.
black- 02 vette vert
be careful running a plugged steel belted radial. they can chew through a plug especially if whatever made the hole tore any of the belts going in or comming out. best bet is to have the tire dismounted and patched from the inside as soon as possible.
03-30-2010, 06:33 PM #9
Ha, ya I've heard that before. Been plugging tires for 30 years though and never had an issue. I think that was a bunch of hype started by the tire companies so people would start paying to bring tires in for a dismount, patch fee and a rebalance personally.
Hell I even have my own tire changer and wheel balancer and I still won't patch a tire
If it ever did chew through a plug, I'd just plug it again
03-31-2010, 08:10 AM #10
Run Flats
You will have a much more comfortable ride without run-flats. When I switched from run flats to regular tires the difference was amazing.
No spares in a corvette since at least 1997. I don't even remember the last time I had a flat tire but without a plug/inflator or something to get you out of a bind if you do have a flat, you should consider getting road side assistance in your auto insurance. It costs like $20 a year.
David in AZ
03-31-2010, 12:14 PM #11Member
- Nov 2008
- harrisburg pa.
03-31-2010, 12:51 PM #12
Yeppers, I've run plugs in steel belted tires until the treads were worn off and it was time for new tires
Maybe others weren't doing it right??
There is a file type tool that you are supposed to stick into the hole, and run it in and out a few times to ream it. Maybe that is filing down the sharp edges of the steel belts??
I don't know, but I've never had steel belts cut through a plug before. Shucks they are difficult to snip off the access with a pair of cutters
03-31-2010, 01:10 PM #13Member
- Nov 2008
- harrisburg pa.
Help Save the Bonneville Salt Flats!
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 04-10-2013, 08:00 AM -
AZFBA Cruise to Tortilla Flats November 7th
By chellzers in forum Western MembersReplies: 2Last Post: 11-09-2009, 10:44 AM -
10-second stock C6 Corvette Z06 on run flats
By gwballin in forum Drag RacingReplies: 13Last Post: 12-09-2007, 11:45 AM -
Goodyear Run Flats 275-40-18
By 4MULAV8 in forum Parts For Sale / TradeReplies: 1Last Post: 08-19-2005, 07:52 AM
