Results 1 to 20 of 24
Thread: Parts list i just ordered
03-27-2010, 08:19 PM #1
- May 2009
- Lima,ohio
White- 2000 trans am
hey whats up guys aint be on here in a while...anyone know what kind of power i will be making with parts an a good tune? an maybe est. 1/4 mile opinions....any help would be grateful. i just ordered..
-102 fast intake with 102 throttle body an fast fuel rails
-ms4 cam prc 6.75 spring an pushrods
-prc 215 heads
-ls2 chain
-36lb injectors
-ls7lifters
-ls6 ported oil pump
-98mm ftp lid
should start getting parts monday..... mods i all ready have long tube ypipe an (dual cutouts not on car yet tho)an hopfully like a month or so a monster stage 3 clutchLast edited by 2000ls1tranz; 03-27-2010 at 08:24 PM.
03-28-2010, 06:03 AM #2
Will that cam clear PTV on your engine?
I would guess you should make close to 450rwhp.
03-28-2010, 08:22 AM #3
Christmas either came late... or early. Post up pics of the install for us.
On the side: Spent 3 years in Ada back in the early '90s -- we were always over in Lima looking for good eats or for something to do. Tripped back out there last spring for the first time. Looks like a lot has changed in 18 years.
03-28-2010, 08:29 AM #4
I would guess 430-440rwhp.
03-28-2010, 11:43 AM #5
- Nov 2009
- NOVA
2002 C5 - M6 - Blue- 2000 Z28 - A4 - Pewter
2000 Z - Light Pewter Metallic - A4 - 130k - Bolt Ons - My Pride and Joy
2002 C5 - Electron Blue - M6 - 32k - My Dream Car
03-28-2010, 04:08 PM #6
- May 2009
- Lima,ohio
it shouldnt have any PTV clearance problems talked to texas speed ..really if depends on ur heads i couldnt run the ls6 2.5 cuz of PTV but the PRC 215 heads will work with the ms4 cam.... stock heads are fine also no PTV problems i was sorta hoping an was told by someone around 470-480
........anyone know any dyno charts for about the same setup?i looked i really couldnt find anything.
03-28-2010, 05:12 PM #7
03-29-2010, 02:02 AM #8
- May 2009
- Lima,ohio
well i did some lookin on google found something a guy with a ls1 1999 vette with prc 215 heads ms4 cam an ls6 intake ...almost same setup just missing the 102mm fast an throttle body he put down445whp an 408 ft lb torque later he got a 92mm fast an put down 482 whp 458 ft-lbs....this is the site .......http://www.ls1tech.com/forums/dynamo...s6-intake.html
03-29-2010, 09:14 AM #9
You can look through this thread and you might find someone with an exact set-up and what numbers they put down.
http://www.ls1.com/forums/showthread.php?t=47179
03-29-2010, 12:46 PM #10
05-09-2010, 08:58 PM #11
- May 2009
- Lima,ohio
car is done
hey sorry guys i aint be on in awhile car is up an running sound fuckin awesome...tune guy come tom. to street tune it ..i didnt change the timing cover seal the one in front the round hard one figured it be ok with the car only having 60,000 miles on it...nope it leaks ...slow leak tho ..lesson learned the hard way...going to fix it after the tune...u think it will be ok tuning it like that??????
05-09-2010, 09:02 PM #12
A little oil leak won't affect the tune. Make sure to keep it topped off and fix that leak as fast as you can tho
┌∩┐(◕_◕)┌∩┐
wouldn't want to fight them!
05-09-2010, 09:14 PM #13
- Thornton, CO
Depends on where it is leaking from....
But likely not with where his issue is.
As for the PTV clearance....that cam is too close for comfort for my liking.
As for the dyno numbers with it....if a car (mostly talking about F-Body's) is set-up to utilize the powerband it won't dyno 470RWHP.
It may with a stock rear and stock gears though. But she ain't gonna run they way she should.
05-09-2010, 09:45 PM #14
- May 2009
- Lima,ohio
ok yea the only reason im going to run it with the leak is cuz the guy is coming from columbus its like i think 2 hour away hes got others to do also an in less than a month hes moving to flordia ..which sucks cuz hes good..
i got every thing from texas speed an they asured me there is no ptv issuses an the car runs an sounds awesome ...found a guy running same setup only he had the 92 fast an i got the 102 fast an he was putting down 488 on the dyno texas speed says the 102 is a 8 rwhp gain with the 102 proved by testing..so im hoping for 496 rwhp...well see tho getting dyno when the performance school opens up here in a couple of months....will let ya all know what it put down when i do it
05-10-2010, 05:26 AM #15
If you are hoping for 496 rwhp you are going to be VERY disappointed.
05-10-2010, 06:27 AM #16
Even if you don't dyno what you want, your still gonna have one SICK car!@
05-10-2010, 06:40 AM #17
- Jan 2006
- Shepherd, Michigan
@ concern over hp numbers .........there is only 1 thing you should worry about when modding a car with a cam etc...and that is ET.
05-10-2010, 09:38 AM #18
05-10-2010, 09:50 AM #19
05-10-2010, 10:25 AM #20
- Jun 2008
- Rochester, NY Rochesterracing.com
- 2000 Camaro B4C
with those mods id be more worried about what i run than my hp/tq #'s
All my parts are ordered now I can't wait!!!!
By Durango in forum General HelpReplies: 0Last Post: 02-21-2011, 12:33 PM -
Ordered new parts
By t5munoz in forum Camaro / SSReplies: 3Last Post: 02-20-2011, 08:33 PM -
Ordered some new parts, am I missing anything?
By JHayesLS1 in forum External EngineReplies: 17Last Post: 02-07-2011, 07:17 AM -
parts list
By Colten W. in forum Internal EngineReplies: 28Last Post: 07-30-2008, 10:57 PM -
Installing new parts, ordered more :)
By M-Ten in forum Firebird / WS6Replies: 29Last Post: 12-18-2007, 05:39 PM
