Thread: tax season!
    Junior Member cj3489's Avatar
    Punxsutawney PA
    Orange and Ghosty
    2001 WS6 m6
    tax season!
    i'm planning on spending about $3,000 on my car (01 m6 ws6). i have a lid, and sfcs already installed. i have a clutch laying in the back seat and am scheduled to have a roll cage installed in about a month. so now its time to research and order parts. i know i want lts and texas speed trues... and i'll need a tune. what to do w the remaining $2,000? should i dig a little deeper and just buy a 9"? orrrrrr a cam and heads? orrrrr spray and a bigger fuel system? orrrrr what? what upgrades are stock fuel system friendly? too many options and i dunno what direction to go. id like to build a solid foundation for other future mods... any input is greatly appreciated! i just wanna do this as right as i can...
    East of Cleveland, Ohio
    99 WS.6 - Modified
    9" if you want a solid foundation IMO. No sense spending $$$$ on adding hp if you just break the rear. Then you'll have to replace it anyway.
    Agree. Best to take care of the weakest link first before throwing money at horsepower.
    Punxsutawney PA
    Orange and Ghosty
    2001 WS6 m6
    i was afraid of that answer... hahahaha... its the bitter truth tho... atleast i can afford full exhaust and a tune too for this season....
    99 WS.6 - Modified
    Yeah, it stinks to spend so much and not feel like you gain anything. But at least it'll let you add the HP without worrying about detonating the rearend. It's not fun - ask me how I know...
    Punxsutawney PA
    Orange and Ghosty
    2001 WS6 m6
    wellll.... i will ask you.... is a full spool good? i don't road race much... pretty much just a sunday cruiser. but i toy w everyone... if its a potential race, i pull the holeshot... hahah
    how many spline do i want? more is better, correct? and will the diff # of splines change anything else?
    is a back brace recommended?
    may as well add the lca reloc brackets, correct?
    swaybar brackets? yay or nay?
    and what about abs and tcs? i could do w/o both, but what does it entail as far as things changing to a "direct bolt in/plug and play" project?
    Jun 2009
    coon rapids, MN
    2000TA
    if it is not a daily driver a 33 spline spool will work.
    Quote Originally Posted by cj3489 View Post
    1. A full spool is not recommended for the street. Lots of posi units to choose from.
    2. I went with 33 spline axles, but any upgrade over the stock axles will probably be sufficient unless you are throwing some serious torque at it with sticky tires. I believe stock is 28, but more is better -- here's a pic for comparison:
    3. I did add a support cover to ours. It was probably more for the "wow" factor than an actual need as our engine is currently not much over stock power level.
    4. The relocation brackets are an option when you order a rear. I did add them to ours and am currently running the middle hole to start out. I think it was like a $100 option. The only issue is that you have to modify your parking brake brackets to make it all work. I did a write up on this in another thread.
    5. Again, you can have welded sway bar brackets attached to the rear -- which I also did on ours. In lieu of brackets, a 3" exhaust clamp will work. The stock sway bar mount is probably a 2-1/2" clamp, pretty low tech.
    6. The ABS/TCS requires a notch machined in the housing ends. It's another upgrade for a price. I did this as well in order to maintain the system on our car.
    Overall, it was pretty much a "plug and play" installation with the parking brake brackets being the most work. You do have to swap over your reluctor rings from the stock axles and then press on the bearings and retainers, so a decent size shop press is a necessity. You can check out ours in this thread. It details the entire installation with pics: http://www.ls1.com/forums/showthread.php?t=127890
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    THIS.
    I'm a prime example. Almost 11K in and no motor mods yet.
    Jeff pretty much covered it on the rear end. I believe on the 9" you can only get up to 31 spline unless you are getting the Wavetrac or the Detroit Locker, which are 35 spline.
  1. Tis the Season, ...Billboard Season...
    Last Post: 09-15-2012, 07:39 PM
  2. 'Tis the Season
    By pajeff02 in forum Most Anything Goes
    Last Post: 12-08-2011, 08:08 PM
  3. End of the season
    By pajeff02 in forum Classic Muscle
    Last Post: 09-06-2011, 11:52 AM
  4. 1st season
    By bamaz28 in forum Almost Anything Goes
    Last Post: 10-22-2009, 10:59 AM
  5. Tis' the Season: Elf yourself
    By Nastyfoot in forum Almost Anything Goes
    Last Post: 11-27-2007, 09:51 PM
