Results 1 to 20 of 24
Thread: Ramps
03-25-2010, 03:38 AM #1
Ramps
I went to the autozone by my house to pick up some ramps to lift my car. When I got in line an employee asked me wat I was using them for and I said to drive up on and put Jack stands on the rear to get the car in the air. He said I was crazy and shouldn't evn try that or the car would end up on top of me. I feel like I've heard plenty of stories of guys doin this. Any input?
03-25-2010, 03:51 AM #2
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
i was wonderin the same thing the other day....i have seen ramps that collapsed but not completely...but that was due to driving up on them and hitting the brakes too hard and they collapse forward...
03-25-2010, 03:51 AM #3
I do that with my front tires on an incline. Just make sure to block the wheels. You must've said something that made him think you were clueless or more likely he was just an autozone dummy.
I always drive up, block wheels, jack car, place jackstands and then move the rhino's under the car somewhere just as an emergency measure.
03-25-2010, 03:59 AM #4
- Apr 2008
- Madison, WI
Well the front tires aren't locked by the transmission or the parking brake so becareful that the car doesn't roll off the ramp when you start lifting the rear end. One thing you could do is jamb a long extension or pry bar between the seat and the brake pedal to hold the brakes while you jack the car up and down. Jamb it in the really tight.
03-25-2010, 04:39 AM #5
Use only jack stands please. There are people that use ramps with no problems, but the front wwheels dont lock. I made, out of some 5/8 wood sheets, some pads to lift each wheel independently so my jack would fit under the nose of the car. I cut 3 squares, 8inch by 10inch and screwd them togather, lifted each wheel, and sat the car on those pads. Now, my TransAm is on 4 jackstands safely.
03-25-2010, 05:26 AM #6
03-25-2010, 07:32 AM #7
I don't really trust ramps myself though I've have used them. Something just bugs me about them. I use four 6-ton stands instead on a concrete floor. Yeah they're heavy and quite large but I know if i place them in the proper fasion the car will not fall. The heavier the better imho. One thing I'd have to say also too, is to keep in mind that a car is very heavy (I know sounds dumb) if it falls it's comming down right NOW. It won't fall slowly and you could just as easily be dead in that same amount of time.. Just be carefull guys..
03-25-2010, 08:05 AM #8
03-25-2010, 08:08 AM #9
I was going to ask how you get the front wheels on ramps? I have not found a pair of ramps that our cars can clear.
03-25-2010, 08:13 AM #10
Are they long as hell? either that or they must be shorter in height?
03-25-2010, 08:22 AM #11
Looks like jacks stands is the way to go. So were would I put the stands to have the suspension loaded?
03-25-2010, 02:19 PM #12
I have ramps that I can drive up on without any issues. I bought them at Autozone probably in 2003. Made of plastic with a very long approach. I thought they were made by Rhino.
03-25-2010, 02:23 PM #13
03-25-2010, 02:47 PM #14
- Dec 2006
- Lubbock, TX
navy blue metallic- 2002 Camaro SS
One thing I did notice about BlackBird0230's ramps tho, is that they are metal and actually look like they have a spot where the wheel falls into once it's at the top. I honestly think that makes it much safer than the Autozone black plastic ramps that pewterz55 is talking about. I have a pair of these and it sucks, cause once you get to the top, there's not much blocking the wheels from having the car roll back down the ramps back onto you =(
03-25-2010, 03:47 PM #15
I used rhino ramps to put headers on and change oil. I have also used them to change the oil in my 05 cc f-250 that weighs 8500lb with no problems so it will suffice for my 3500lb car too. the rhinos have a groove at the edge to keep your car from rolling off them also.
03-26-2010, 10:12 AM #16
03-26-2010, 10:45 AM #17
Unless these ramps are damaged in some way, I don't see how they would collapse under any normal sized car made today. Big huge trucks/suvs might be a different story.
I've got to get me a new set, I have a yellow set similar to those blue ones and these C6 tires (rear especially) will not fit in the grooves. Those Rhino ones will be my choice either these or these.
03-26-2010, 11:35 AM #18
Ive used this idea many times to check brake lights many times when I worked at Cat. If using ramps, its a great idea. Never thought of it as I don't own any ramps. Jack stands and a nice long, low profile jack is IMO easier.
Jack the front up and place jack stands under the K member. Jack rear end of car up from the differential.Then rig something up to rest your back tires on. I used two large wooden header beams we had laying around from a house remodel. Worked great. Either way, just have to set those rear tires down on something stable to load the rear suspension. Installing SFC's or setting pinion angle I assume?
03-26-2010, 01:08 PM #19
03-30-2010, 10:37 AM #20
Question: Where to buy ramps
By JoshieDoom in forum General HelpReplies: 15Last Post: 02-24-2008, 03:29 AM -
car ramps (lift)
By ssmike in forum General HelpReplies: 62Last Post: 12-09-2007, 05:47 AM -
Ramps
By jag42420 in forum General HelpReplies: 5Last Post: 04-14-2007, 04:19 AM -
Best place to buy 4 car ramps?
By Firebird Phoenix in forum Parts Wanted / TradeReplies: 2Last Post: 02-28-2007, 08:00 PM -
Ramps
By kemp in forum ToolsReplies: 8Last Post: 05-05-2006, 05:56 PM
