Results 1 to 15 of 15
Thread: spark plug gap
    Member dav-02ws6-m6's Avatar
    Mar 2010
    VA
    2002 trans am ws6
    spark plug gap
    hey guys i was hoping if somebody can help me.. the thing is like i said on my other post that i was going to do the tune-up on my car. well i finally started today BUT i was getting ready to start on the spark plugs when realize that i didn't know the the spark plug gap... the car has boush 4 tip spark plug and i am going for NGK iridium IX ( TR51X ) i dont have anything on the car right now except for the air lid. cb and maybe latter some LT headers. thank you an advance for all the help...
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    If I remember correctly, the gap for the LS1 is .40 or .45. I could be wrong though. Others will chime in here.
    My TR55's are gapped at .054". Not sure what to do with a platinum tip plug. Cutlass just posted some great info on plugs -- I'll find it and post the link.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Anywhere around .050" is pretty reasonable for our cars. There are reasons to go a little bigger gap and there are reasons to go a little smaller gap. Pick a number and go with it You can look up your plugs on NAPA's website and they'll list the recommended gap
    Plus I think the NGK's come pregapped so just check them all and make sure there all the same.
    Mar 2010
    VA
    2002 trans am ws6
    thank you guys
    Mar 2010
    VA
    2002 trans am ws6
    well i check the NGKs and they are set up on .035 so i'll just go on the 40's thanks for the help again..
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Member blackbird0230's Avatar
    Jul 2009
    Colorado
    2002 Trans am WS6 pkg
    I went with .40 on my NGK55's
    Although I think .50-.60 is recommended.
    Mar 2010
    VA
    2002 trans am ws6
    yea i'm thinking i'll go from 40 to 45 sense i don't have any mods on the car.
    Mar 2010
    VA
    2002 trans am ws6
    well guy i'am done with the spark plug. i already went and drove it an seem like they are working fine. i just hope that i don't have to do that in a while. thank for all the input and help.
    North Jersey
    2004 GTO M6
    Shouldn't have to. Enjoy.
    Member Lawnboy's Avatar
    NY
    01 SS Built LS6 740RWHP
    The stock gap is big! around 55, some say 60, i run TR6IX NGK's , awasome plugs , car runs smoother with them.
    OK i run a 32-35 spark gap , Yes its tight , but i am procharged and at 15 psi, with the high cyclinders pressures a small gap keeps the spark strong, and wont blow out.
    on a NA car i would stay with a 45-50 gap for a better burn
    The bosh 2, 3 or 4 tip plugs are not a good choise in the LSX motors IMOP,
    i seen a car that was being dyno tuned and the dyno, the dyno spark plug wire pick up couldnt read the rpm of the motor, it was becuses of the 4 way bosh plugs that the customer was using, I guess it was causing a multi spark and the pick up was reading it wrong
    Member squirlnutz's Avatar
    oklahoma
    2000 trans am
    you are correct. .40
    Also, -.04 for every 50hp added, Naturaly asperated ONLY!
    NY
    the stock gap looks much wider than 40 i seen some plugs come out with 50-60
  1. What kind of oil 5w30& spark plugs&spark plug wire
    By ROMERO98Z28 in forum General Help
    Last Post: 09-01-2009, 01:50 PM
  2. Spark Plug Gap
    By slpgto2004 in forum GTO
    Last Post: 10-05-2007, 04:58 AM
  3. spark plug
    By SuPeRmAn23 in forum External Engine
    Last Post: 08-21-2007, 04:54 AM
  4. Spark plug wire and plug!
    By RYDER661 in forum General Help
    Last Post: 03-13-2006, 09:01 PM
