03-21-2010, 05:54 PM #1Junior Member
- Jul 2008
- Pennsylvania
Mystic Teal- 2000 Z28
1997 Trans AM Will not start please help.
I'm working on a '97 Trans Am and I replaced a turn signal bulb socket in the front and in the process removed the horn for easier access. Now the car will not start. I was thinking perhaps removing the horn triggered something in the anti-theft system as it utilizes the horn and lights when the alarm goes off. The red LED security light on the dash was flashing intermittently but now doesn't come on at all. Normally when I turn on the key all the idiot lights flash on for a second prior to starting the car but now nothing at all lights up. The headlights turn on and the dome lights turn on but none of the dash lights are coming on at all and it does nothing at all when you try to start it. I've searched the internet and the only solution I found was to disconnect the battery for 10 minutes then connect it and turn the key to the accessory position for 10 minutes until the anti-theft light stays solid, and then the car should start, I've tried this and several variations of this with no luck. The anti-theft light isn't lit up, none of the dash lights at all lite up. I called the local Pontiac dealership on Friday and they want me to have it towed in for service. I really don't want to spend all that money just to disarm the anti-theft if that is the problem. I'm borderline retarded so I'm thinking maybe it's something obvious that I'm missing. Any and all help would be greatly appreciated. Thanks in advance ~Mark
03-21-2010, 09:08 PM #2
Did you remove any ground wires? PCM ground is over there. When you hit the key do you hear the fuel pump.
03-22-2010, 09:25 AM #3Member
- Feb 2008
- Russellville, MO
You don't have to pay tons of money to bypass the VATS module. Just do the VATS bypass yourself. I just did it and it was very easy. Make sure you check your grounds, you make not have one hooked back up.
03-22-2010, 05:52 PM #4Junior Member
- Jul 2008
- Pennsylvania
Thanks for the suggestions
Thanks a lot for the suggestions, it ended up being a fuseable link from the battery to the starter so I replaced it and I'm back on the road. Thanks again. ~Mark
03-24-2010, 10:37 AM #5
03-26-2010, 06:45 PM #6Member
- Feb 2008
- Russellville, MO
I didn't know there was one either, the location would be a good thing to know in case anyone else has this problem.
03-29-2010, 09:14 PM #7Junior Member
- Jul 2008
- Pennsylvania
I apologize for the late response. The car had a stereo and alarm installed before I bought it and I'm uncertain if the fuseable link is from the factory or is part of the alarm system as everything seems professionally installed. I tend to believe it isn't from the factory because it isn't with the bundle of factory fuseable links behind the battery. I have a 2000 Z28 which is wired similar to the Pontiac and it doesn't have one in this location. Sorry for any confusion. If it does happen to be factory it is located in the black plastic wiring cover on the inside passenger's side fender wire loom.
1997 Trans am
By [WS6] in forum Vehicles For Sale / TradeReplies: 1Last Post: 09-29-2012, 02:49 PM -
For Sale: 1997 Trans Am
By LTJUAN in forum Vehicles For Sale / TradeReplies: 1Last Post: 10-14-2008, 10:40 AM -
My Winter ride (1997 Eclipse) Won't start!
By Justin93 in forum General HelpReplies: 12Last Post: 08-26-2008, 04:56 PM -
1997 Camaro V6 won' start
By oldguy in forum General HelpReplies: 4Last Post: 05-19-2007, 03:59 PM -
1997 Trans Am WS6 M6 H/C N2O
By FRCBobby in forum Vehicles For Sale / TradeReplies: 5Last Post: 03-15-2007, 05:47 PM
