Results 1 to 20 of 39
Thread: Air removal
03-20-2010, 09:51 AM #1
Air removal
Can anyone give me a better picture of its location? I'm going through the header install sticky steps and that picture is hard to see.
Also when I remove it I read there is an electric pump behind the driver headlight which I can get to from underneath...CORRECT?
03-20-2010, 10:00 AM #2
Yes correct, disconect it and remove it , remove all the AIR hoses, its real eazy, but it might through a SES light your tuner can turn that right off
03-20-2010, 10:22 AM #3
Since I bought non egr/air headers I don't need a block off plate for anything right? So since I have no idea what this air thing is and its not going back on the headers, could I leave it in the car for now or do I have to remove it right now?
I understand about the tune, I have it in the plan.
This may be a far cry for help but do you happen to know the spark plug gap off the top off your head?
03-20-2010, 10:53 AM #4
yes you can leave the pump in the car , i would get the rubber hoses removed, it will clean up under the hood a bit, looks cleaner without them,
Plugs Stock AC delcos are about 50-60
NGK TR55 or TR6 40 no blower 30-35 blower,
I would Get the NGK IX irridoum's nice plugs, my car runs smoother with them
and you can run them on a supercharged/turbocharged LS1
03-20-2010, 11:21 AM #5
- Feb 2007
- San Diego, CA
Pull the fuse for the pump and it won't come on.
That's what I did til I got around to taking it all out.
03-20-2010, 11:22 AM #6
- Jan 2010
- texas
silver- 2000 formula
remove the pump under fuse boxes..........4 10mm bolts.......remove hoses from exh manifolds......remove hoses from air pump.....remove diverter valve , its that the plastic thingy where all the hoses meet on top on the drivers side valve cover.....the metal bracket that holds the DV is held down by a 10mm on a valve cover bolt and a 15mm on the back of the head.....the 15mm is a PITA but can be removed.............think GEARWRENCH......the DV has a vacum hose....pull off and cap......pull fuses for air pump......all done
03-20-2010, 11:24 AM #7
- Jan 2010
- texas
03-20-2010, 11:24 AM #8
- Jan 2010
- texas
03-20-2010, 11:25 AM #9
- Jan 2010
- texas
03-20-2010, 11:26 AM #10
- Jan 2010
- texas
03-20-2010, 11:27 AM #11
- Jan 2010
- texas
03-20-2010, 11:28 AM #12
- Jan 2010
- texas
03-20-2010, 11:34 AM #13
- Jan 2010
- texas
03-20-2010, 02:52 PM #14
thanks guys! this should be a damn sticky for those who have no idea what it is
03-20-2010, 05:45 PM #15
good idea pull the fuese
03-20-2010, 06:43 PM #16
Here is a complete write up on this topic with pics: http://www.ls1.com/forums/showthread.php?t=130641
03-20-2010, 06:44 PM #17
03-20-2010, 07:15 PM #18
if you have long tube headers it might take longer for your O2's to heat up without the air pump, this will give you a rich idel and stumble at a stop comming off the clutch.
03-20-2010, 07:16 PM #19
- Jan 2010
- texas
mines a auto...........but i feel no diff since the headers and air removal at idle or cold
03-20-2010, 07:22 PM #20
my friend had a really poor idel at cold start up,
gas removal
By redrocketws6 in forum Firebird / WS6Replies: 12Last Post: 03-12-2011, 06:28 PM -
EGR removal
By kev70ss in forum General HelpReplies: 2Last Post: 03-19-2008, 10:01 PM -
Oil pan removal
By 346ci in forum General HelpReplies: 3Last Post: 03-19-2008, 12:53 PM -
EGR removal
By knewsock in forum External EngineReplies: 7Last Post: 10-06-2006, 01:57 PM -
EGR removal
By zybermunster in forum LT1Replies: 6Last Post: 08-27-2005, 12:15 AM
