03-19-2010, 02:58 AM #1
Has anyone done the roller rocker upgrade?
I'm wondering if anyone has switched out their stock rocker arms for a higher ratio roller rocker on their LS2 motor? If yes, what HP improvements did you see, was the job easy enough and striaght forward?
I did a Roller Rocker change on my 94 Vette LT1 back about 10 years ago, just looking to see if things are about the same these days.
03-25-2010, 05:56 PM #2
So I guess no one has done this upgrade??? Just double checking, surprising if no one has
xfingers:
03-27-2010, 03:38 PM #3Senior Member
- Mar 2008
- OHIO"S only 9 second GTO
Phantom Black Metalic- 2005 GTO
Its been done, look under the vette section,depending on mods,I would check pushrod lenghts,im running l92 heads ,they take offset rockers,used to do this on the old sbc motors and pick up some power on the exhaust side.
03-28-2010, 06:39 PM #4
Thanks I'll check it out...
1.7 to 1.8 Roller rocker upgrade on turbo charged
By bly123 in forum Internal EngineReplies: 0Last Post: 10-26-2008, 07:32 PM -
Roller rocker question
By Johns00Z28 in forum Internal EngineReplies: 61Last Post: 09-11-2007, 02:56 PM -
Roller Rocker Help
By WS6ICK in forum Internal EngineReplies: 1Last Post: 09-06-2007, 03:33 PM -
Roller Rocker advice
By LSXWS6 in forum Internal EngineReplies: 22Last Post: 06-29-2007, 03:29 PM -
Roller Rocker Arms
By lonewolf37 in forum Internal EngineReplies: 10Last Post: 07-05-2006, 06:34 PM
