    Mar 2010
    Houston, TX
    2000 Trans Am WS-6
    Headlight/Foglight Question?
    When I turn on my parking lamps I only want my fog lights to come on. But... When I do, the headlights pop up. How do you just make the fog lights come on without the headlights coming up? I have seen it on other TA's, but mines doesn't work that way. 2000 WS.6
    phoenix
    04 2500 4x4 crew cab
    do your headlights ratchet when you arm the alarm or turn off the headlights?
    Try roasting your crow. It'll be easier to get down.
    I like grilling mine with a nice brown sugar based rub
    Mar 2010
    Houston, TX
    2000 Trans Am WS-6
    Yeah, I changed the gear in the motor, but still grinds. But should that matter? When I turn just the parking lights on the headlights pop up but they don't come on. I don't see why the headlights come up with just the parking lights on???
    Member stew215's Avatar
    Dec 2009
    Levittown, PA
    yes it does matter... I was having the same problem until i replaced my head light motor.. It also made my headlights pop up instead of the horn beeping when I hit the lock button on my remote. Once you get rid of the grinding it will work properly.
    Member Baluchitherium's Avatar
    It has a big wing!
    Yeah these headlight gears will cause all sorts of wierdo problems...
    If you haven't already, try the free fix here http://www.bfranker.badz28.com/headlightfix/#FreeGuide
    I know it's an LT1 but the point is the same. Good luck!
    phoenix
    or you can do like me and have a "good" week, where the problem gives you a small respite, and your car doesn't sound like ass every time you stop at circle k.....twice.
  1. noob headlight/foglight questions
    By L...S...1 in forum Camaro / SS
    Last Post: 09-28-2009, 09:19 PM
  2. Headlight/ foglight HID kits?
    By sic2001 in forum Appearance Section
    Last Post: 01-19-2008, 12:22 AM
  3. Headlight/ foglight HID kits?
    By sic2001 in forum General Help
    Last Post: 01-01-2008, 11:15 PM
  4. headlight question
    By transamdude99 in forum Firebird / WS6
    Last Post: 04-05-2007, 12:10 AM
  5. 97 Bird Headlight question also engine noise question
    By Zapper2003 in forum General Help
    Last Post: 12-13-2006, 04:03 AM
